Old 06-24-2009, 01:47 PM
Juraj Bernáth Juraj Bernáth is offline
Default HD PCIe with SSL Delta link MADI HD Alpha link MADI AX
I'm using this set up with Power Mac G5 QUAD and I can't get signal into DAW and from DAW to my monitors. I probably have bad I/O settings but I clicked on "Default" in I/O set up window and I'm using only first 1-8 channels. I can see LED's lightning on Alpha Link converter on channels 7 and 8 when I'm recording but there's no signal in A-7 and A-8 inputs in Pro Tools. Also my main output is set to A 1-2 but there's no signal in Alpha link when I switch to DA meters. I have MADI AX connected to MADI HD bridge with MADI cable and bridge conetcted to my Accel core card (I have PT HD2) and I have no idea where's the problem. Can someone help me, please? What I'm doing wrong?
Old 06-24-2009, 06:02 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Default Re: HD PCIe with SSL Delta link MADI HD Alpha link MADI AX
I have an HD4 with two DeltaLinks, but they're connected to an SSL C200 console, so I can't really relate to the AlphaLink routing. I'd really try connecting with SSL support to confirm your setup. They are AWESOME at coming up with the silliest things you may have overlooked.
Have you tried going to their site's support section? Lots of FAQs to help.
http://www.solidstatelogic.com/support/Alpha-Link/
or
http://www.solidstatelogic.com/support/Delta-Link/
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 06-24-2009, 08:46 PM
I'll try to contact them. Thanks!
Old 09-10-2009, 07:13 AM
Matts Matts is offline
Did you get everything up and running?
-matts
Pro Tools 10 and SSL X Logic Alpha Link Madi AX Basslab macOS 0 01-25-2013 09:07 AM
HDX Madi with SSL Alpha-Link AX sammyfarr Pro Tools HDX & HD Native Systems (Mac) 3 08-11-2012 04:11 PM
PT 10 + SSL Alpha-Link Madi-AX and MIDI bfire Pro Tools 10 1 01-14-2012 04:42 PM
does Alpha-link Madi works with PT9? coloquinte Pro Tools 9 21 07-11-2011 11:09 PM
SSL Alpha Link Madi AX and xtreme64 card bluemix macOS 4 01-04-2011 06:23 PM
