Major issues loading Pro Tools 8
Hey all,
I just upgraded my PC, purchased PT 8 & updated to 8.0cs3, and bought a used digi 002. Thought I was making my setup more efficient and stable, but it seems I just created more problems for myself. I'm having serious issues launching Pro Tools- blue screens, DAE 1115 errors, and freezing after DAE loaded. I just can't get past the loading phase after all the plugins load up. I've done just about every optimization and tweak in the "Best Core 2 Desktop" and "General Troubleshooting Guide." There is no IE8 on the pc. I called digi & the tech seemed to think it's a firewire issue. Had me take out a previous Via PCI card, change ports, etc. I also have a 002 mixer and used different firewire cables so I don't think it's related to the interface. He really had no idea though, and nothing worked. I ordered an ADS Pyro card just in case, but a few members seemed to think the problem may be OS or OC related. Here's the report: SiSoftware Sandra System Model : Gigabyte Technology Co., Ltd. EP45-UD3P Workgroup : WORKGROUP Host Name : Sundiata-PC User : Sundiata Processor Model : Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz Speed : 3.4GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing System Mainboard : Gigabyte Technology Co., Ltd. EP45-UD3P BIOS : Award Software International, Inc. F9 (04/16/2009) Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.25GB DIMM DDR2 Chipset Model : Giga-Byte P45/P43/G45/G43 DRAM Controller Front Side Bus Speed : 4x 400MHz (1.6GHz) Total Memory : 4GB DIMM DDR2 Memory Bus Speed : 2x 480MHz (960MHz) Memory Module(s) Memory Module : Patriot Memory 6400LL Series 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-12 3-23-6-3) Memory Module : Patriot Memory 6400LL Series 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-12 3-23-6-3) Video System Adapter : ATI Radeon HD 3600 Series (120 SM5.0 725MHz, 512MB DDR4 2x1GHz, PCIe 2.00 x16) Graphics Processor Adapter : ATI Radeon HD 3600 Series (120SP 725MHz, 512MB 1GHz) Storage Devices OCZ-VERTEX 32GB (SATA300, NCQ, 32MB Cache) : 30GB (C:) WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) : 466GB (H:) WDC WD5000KS-00MNB0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (D:) SONY CD-RW CRX220E1 (ATA33, CD-RW, 2MB Cache) : N/A (F:) _NEC DVD_RW ND-2500A (ATA33, DVD+-RW, CD-RW, 2MB Cache) : N/A (G:) Logical Storage Devices System Reserved : 100MB (NTFS) AudioDrive_1 (H:) : 466GB (NTFS) @ WDC WD5001AALS-00L3B2 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 32MB Cache) AudioDrive_2 (D:) : 466GB (NTFS) @ WDC WD5000KS-00MNB0 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) Hard Disk (C:) : 30GB (NTFS) @ OCZ-VERTEX 32GB (SATA300, NCQ, 32MB Cache) Optical Drive (F:) : N/A @ SONY CD-RW CRX220E1 (ATA33, CD-RW, 2MB Cache) Optical Drive (G:) : N/A @ _NEC DVD_RW ND-2500A (ATA33, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Giga-Byte LPC Interface Controller LPC Legacy Controller 1 : ITE IT8718F Audio Device : Giga-Byte HD Audio Controller Audio Device : PC Partner RV635 Audio device [Radeon HD 3600 Series] Disk Controller : Giga-Byte 4 port SATA IDE Controller Disk Controller : Giga-Byte 2 port SATA IDE Controller Disk Controller : Giga-Byte JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : Giga-Byte USB UHCI Controller #4 USB Controller 2 : Giga-Byte USB UHCI Controller #5 USB Controller 3 : Giga-Byte USB UHCI Controller #6 USB Controller 4 : Giga-Byte USB EHCI Controller #2 USB Controller 5 : Giga-Byte USB UHCI Controller #1 USB Controller 6 : Giga-Byte USB UHCI Controller #2 USB Controller 7 : Giga-Byte USB UHCI Controller #3 USB Controller 8 : Giga-Byte USB EHCI Controller #1 FireWire/1394 Controller 1 : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek RTL8168B/8111B Family PCI-E Gigabit Ethernet NIC (NDIS 6.0) (Ethernet, 100Mbps) Network Adapter : Realtek RTL8168B/8111B Family PCI-E Gigabit Ethernet NIC (NDIS 6.0) #2 Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows 7 Ultimate 6.01.7100 Platform Compliance : x86 Windows Experience Index Current System : 5.2 Power Supply: OCZ 700W Mod Xtream-Pro I know.. I know.. Windows 7.. It's running on 32 bit and my computer guy convinced me at 32 bit it should work with anything that Vista 32 bit can work with. I'm not the most pc savy guy in the world, so I didn't know enough to challenge him on that. I'll get Vista Ultimate if you guys think that will cure all, but I was just trying not to spend too much more on anything that's not gonna fix my issue. So I just wanted to be sure before buying it. 7 is free for a year so I rolled with it. Please help me get this @#$% thing running smoothly! |
Re: Major issues loading Pro Tools 8
You may have some success rolling the FW driver back to the legacy driver. Heres how (I'm not at a Win7 machine and going from memory here so these are a rough guideline) open up the Device manger page. You can get there by pressing Alt+Pausebreak (this will bring up what used to be the system properties page) and select Device Manager from the choices on the left hand pane. Right click the FW adapter and select update driver and "let me choose from a list" with any luck you will see two drivers listed with the top one being Texas Instruments OHCI FW driver and the lower choice will read some thing like "Legacy 1394 OHCI bus driver" Select the legacy driver and close the update dialog boxes. Reboot and make sure that the Legacy driver is the top choice and try launching Pro Tools. Deleting Pres and Data bases would not be a bad idea either. This may solve you DAE 1115 error or it may not. Its probably not going to stop any blues screens, for that I would make sure you have the very latest Pace drivers. If you update the firewire driver and the Pace driver and its still not working I would re install Pro tools as it may not have installed correctly as it may not have read the 002 correctly. Thats the best I can do. I hope it helps.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Huge thanks to you Sunburst, I'll try installing the legacy driver, uninstalling and reinstalling PT, and will update the PACE drivers (again). If I get the same thing, I'll shell out the $150 for vista business & go from there.
I had a lot of problems with my 003 rack+ on XP Pro when I first got it. When I finally got the Siig Firewire card things improved drastically. Anyway, one problem I had (and still have occasionally) is PT 8cs3 freezing on the DAE Loaded screen. I have no idea if this is the right thing to do, but the only way I get around it is to momentarily power off the 003 and then back on. It goes through loading the MIDI stuff afterwards and I'm able to run PT again. If I cycle the power fast enough I don't even get the "PT cannot communicate with the 003" message, but I really hate cycling the power like that - it can only damage the unit, but what else can be done? I've heard you should NEVER reseat the firewire cable with the power on. Fortunately for me now it usually loads with no problems...
Well thank you too, cwsand. I went ahead and bit the bullet on the OS. Bought Vista Business (w/ the Windows 7 free upgrade of course). I'll have that installed, will optimize, cancel the OC for now, and uninstall and reinstall PT. Then I will return to you all!! Because after dropping $300 in software alone between PT 8 and Vista, another $800 or so in PC hardware, and $400 on my 002, I NEED this to work.
Please be careful not to allow IE8 to install on your new OS.
Thanks. Is there an easy way to make sure that doesn't happen? While installing it? Or to I just have to uninstall after?
If you are going out to buy Vista, try to get a package that came out prior to IE8.
And this may help, http://support.microsoft.com/kb/957700
Hi Guys!
Just a quick reply: I too am having enormous difficulties with loading PTLE 8.0cs3 with 003 Factory. Basically I have the same problem as cwsand wrote above - the only difference is that I have not yet found a workaround. When I first installed PT (I bought all the equipment new) and encountered these problems I disabled the on-board firewire card and bough the Siig PCIe firewire card which is certified by DigiDesign. I thought that - based on what I have read - that this will solve the issue. It definitely helped ... but it did not clear all the issues. I have Visa 32-bit installed with IE7 and Firefox. If you guys have any ideas what can be done to solve this "stuck on DAE Loaded" screen please post a reply. Many thanks. |
avid recording studio with pro tools SE major issues | michaud | Pro Tools SE and Essential (Win) | 2 | 07-02-2013 04:47 PM |
Pro Tools 8.0.5 Major Issues | Oldskewl | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 06-22-2011 05:25 PM |
Loading Plug-ins Issues Intel Pro Tools LE 7.1.1 | S133 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-30-2006 07:46 AM |
major, major issues | satchvai | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 02-03-2006 12:10 PM |
Major System Crash when loading PT | tommytime | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-18-2003 07:59 PM |
