Old 11-19-2011, 09:04 PM
David Cannon David Cannon is offline
Default MP3 Option not working in Pro Tools 10
I have just installed upgraded to PT10 and tried the bounce as an MP3 option to itunes but it says that MP3 option has expired.
This is strange because I thought it was an added feature to PT10. I have purchased the legacy MP3 option in the past.
I do not see any option to install it either.
Ant ideas welcome.
Thank you
Old 11-19-2011, 09:13 PM
ReynaldoPena ReynaldoPena is offline
Default Re: MP3 Option not working in Pro Tools 10
yeah, I deleted my DAE preferences and now pt is not giving me my Mp3 option
Take care brush your hair,
Rey
https://r-e-y.com/
macOS Ventura
Pro Tools 2022
iMac (Retina 5K. 27-Inch, 2020)
Processor 3.6 GHz 10-Core Intel Core i9
3.6 GHz Dual-Intel Core i7
16GB ram
AMD Radeon Pro 5700 8GB
Shure SM7B Mic
Pro Tools | Carbon
Komplete Kontrol M32
AKAI Mpk3 Mini
KALI Lp 6 (2)
Old 11-20-2011, 12:04 AM
Emcha_audio's Avatar
Ant ideas welcome.
Thank you
Before installing PT 10 did you uninstall the old version you had and made sure to erase the folders that went with it?
Manny.
Wave-T.com
Old 11-20-2011, 12:34 PM
timecode timecode is offline
System?
Have you installed any other drivers after your PT install?
I had a similar issue installing mbox drivers after PT. Turns out it has to do with the interlock drivers and the Mbox overwrite the new ones with older ones.
Need the most current ones from Pace.
PT Ultimate with Native pcie card + Omni - 2014 MacbookPro - OSX Catalina - 16GB Ram - Sonnet TB Chassis -UAD2 Quad
Old 11-20-2011, 03:36 PM
Yes, it does say to update the iterlock driver. The update interlock driver wont install either because it can't find the license support.msi or is in use on a network drive.
Do I need to install the interlock drivers from a different place?
thank you for your help.
Old 11-20-2011, 04:54 PM
Sounds familiar.
I ended up uninstalling everything and made sure all folders that get left behind are removed.
Start the installation process again but ensure you install PT last.
This was the only way I could get past these installation issues.
Let us know how you go.
Old 11-20-2011, 11:57 PM
ANP57 ANP57 is offline
Hi, I ended up with the exactly same situation.
With fresh install of Win 7 64bit Ultimate + PT 10.0.0 the mp3 bounce works.
When I started installing plugins somewhere on the way the Ilok driver did get replaced (I guess) so I ended up with "mp3 option expired".
Tried to install the latest Ilok driver but it stopped when the "license support.msi" was missing.
I´m going to do more troubleshooting later today to find out which plugin install caused this.
Core2Quad Q6600
Asus P5K
Corsair 4Gb
WIN 7 Ultimate, PT 10.0.0
002R+Command8
Old 11-21-2011, 12:29 AM
Core2Quad Q6600
Asus P5K
Corsair 4Gb
002R+Command8
Have you downloaded the latest version of the ilok authorization tool and the drivers from Ilok.com?
Manny.
Wave-T.com
Old 11-21-2011, 03:03 AM
Yes, so the very latest driver install was tested.
Old 11-21-2011, 03:32 AM
bonzerboy bonzerboy is offline
I think I went thru this to but works now. Avis should make clearer instructions for installs.
Wow am I groovy or what
mp3 option not working pt LE 7.4 singingbassist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-25-2013 07:16 AM
MP3 Option not working in Pro Tools 8.1 HD ctyelvis Pro Tools TDM Systems (Mac) 7 03-15-2012 11:43 PM
MP3 Option not working in Pro Tools 10 David Cannon Windows 6 12-03-2011 10:06 PM
MP3 Option Not Working kfoody Pro Tools M-Powered (Win) 6 04-02-2011 10:26 PM
Help me get MP3 option working SteveGarman Pro Tools TDM Systems (Mac) 3 06-19-2006 04:33 PM
