Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 05-01-2011, 02:33 AM
timecode timecode is offline
Default Recommended Midi Interface for PT9
I am in the process of building my PC to run PT9|HD Native with an Omni Interface. Will post my specs once I know it is running smoothly!
I am looking for sugestions/recommendations for a Midi interfaces that will work nicely with PT9.
I can possibly get the legacy Midi I/O at a reasonable price if these are any good.
Thanks in advance.
Old 05-03-2011, 07:22 AM
nst7 nst7 is offline
Default Re: Recommended Midi Interface for PT9
It may depend on how many midi inputs/outputs you need at one time. Any of the inexpensive M-Audio midi to usb interfaces should work fine (like the Uno). Also, any of the M-Audio Axiom keyboard controllers also serve as midi/usb interfaces. Some other brands of controllers may also do this.
Old 05-05-2011, 03:21 AM
MusoPro's Avatar
MusoPro MusoPro is offline
There was just a post about this.
Yes the Digi MIDI I/O works great.
M.
Old 05-05-2011, 08:53 AM
I could not get my UNO to work with Windows 7(was fine on XP), but my MOTU Fastlane USB (2x2) is working dandy.
Old 05-05-2011, 10:26 AM
noah330 noah330 is offline
I second the MIDI IO from Digidesign. Mine was about $200 used and has 10 ins/outs. I only use 1 set but in my experience whenever I had less then 8 eventually they all get used.
Plus it matches my two 192s :).
Setting up a USB/Midi Controller while using a tascam audio/midi interface disabledpro001 macOS 5 03-30-2012 07:06 AM
Recommended Win7 PC Card Interface For Notebooks brigwyn Windows 2 12-11-2011 08:56 PM
using MIDI interface on 002 to control a Line6 Vetta by midi Jenk2k MIDI 2 06-13-2008 05:46 PM
Recommended MIDI interface primafacie MIDI 5 12-09-2003 01:47 PM
recommended MIDI configuration KSutton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-20-1999 10:19 AM
