Old 05-17-2013, 06:56 PM
jeff markham's Avatar
jeff markham jeff markham is offline
Default "Error configuring CNTRL|24 Personality" in Pro Tools 10 with Control|24
I've upgraded to PT10 and never ran the Control 24
on this particular system.
When I scan the Ethernet peripherals, it sees the Control
24 (CNTRL|24). But, when I select it, the "Offline" status goes
dark and then a dialog comes up says:
"Error configuring CNTRL|24 Personality" and it doesn't connect.
I can see the cable carrier is lighting up....
Is there a firmware upgrade or something that is required with 10?
Help is much appreciated...
Thanks
jeff
Old 05-17-2013, 07:11 PM
Default Re: Protool 10 and Control 24
I should add the Control 24 has been in storage for over a year.
Perhaps a Sys Reset is in order?
Old 05-26-2013, 10:56 PM
Default Re: "Error configuring CNTRL|24 Personality" in Pro Tools 10 with Control|24
Per my other post .. turned out it was the bundle file. .. all is well.
PT10/Digi 003 - Error occurred while trying to load the controller personality "003" J-Xile 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-14-2015 08:36 PM
MBox 3 error/warning "Controller Personality?" Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 03-24-2014 05:45 AM
2 Problems after Upgrade PT9 to PT10: "Controller-Personality MBox3" and "MP3.dll" Eviltubbie Windows 5 07-03-2012 10:39 AM
Error occured while trying to load the controller personality "HUI" speng 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-26-2009 11:21 AM
Control 24 "Personality" Issue with PT 6.01 digi2000 Pro Tools TDM Systems (Mac) 7 07-22-2003 05:34 AM
