Old 07-30-2002, 08:28 AM
gavmac gavmac is offline
Default Experienced Pro Tools User\'s
I am currently trying to set-up Pro Tools to allow me to change plug-in parameters using a Korg MS2000's knobs sending Midi CC messages.
I have gone into peripharals ( bad spelling ) and set the profile for the CS-10 midi controller. What I want to know is what CC messages do each individual plug-in parameter respond to ?? They must all be different but I can't see how you can find this info....
Please Help
Cheers
Old 07-30-2002, 09:07 AM
crs117 crs117 is offline
Default Re: Experienced Pro Tools User\'s
If i am not mistaken the only 2 controllers that are able to control digi specified parameters (pluggin controls and things similar), would be the control 24 digi console, and the mackie hui (and the soon to be released 002). the only other way that other digital consoles can access those parameters would be through some form of hui emulation.
i could be totally wrong but, i dont think digi wants any consoles other then their licensed ones to enjoy those priceless (in all seriousness) benifits.
Christian
Old 07-30-2002, 09:13 AM
Roy Howell Roy Howell is offline
Hey Christian,
How's that hammer dulcimer coming? Do you get a chance to play it much?
~Roy [img]images/icons/wink.gif[/img]
sorry to interrupt, Gavmac... [img]images/icons/smile.gif[/img]
rh music
Old 07-30-2002, 09:20 AM
Its great, and thanks for asking roy. I will tell you that to sound good on the hammer dulcimeris one thing, but to actually be good is another. Its a really fun, and challenging instrument, and in the long run i am sure it will make me a better musician (although not much is required for that). I have been listening to a lot of Rich Mullens music, and he is a stud on the thing. I simply wish i had more time (band every weekend and most wed's, work, piano, guitar etc...).
Christian
Old 07-30-2002, 11:07 AM
Bastiaan Bastiaan is offline
JLcooper cs-10 can also change the plugin-settings....and if you can program your machine, you should be able to get some control. Look in help/control-surfaces or something.
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 07-30-2002, 11:11 AM
Surely any control surface will use either CC's or Sysex to move plug-in parameters, so why can't you just use any thing that transmits these messages to control Pro Tools.
Old 07-30-2002, 03:21 PM
You can, but you have to emulate one of the protocols supported by protools. The protocol for the jlcooper cs10 is the only one they published
Link to pdf-file with the cs-10 command set explained
What's that?
Bastiaan
Old 07-30-2002, 04:13 PM
Stone Knife Stone Knife is offline
The Tascam US-428 will also work in PT
Old 07-31-2002, 06:43 AM
Thankz I'll check them out....
Old 07-31-2002, 09:50 AM
minimoog minimoog is offline
or you could buy a mac and select the appropriate device as controller in OMS.
makes it very easy, even if you can't run delay, eq and compression on 40 channels at once.
Im getting pretty experienced with Pro Tools SE timcrow420 Pro Tools SE and Essential (Win) 4 07-05-2012 11:41 PM
Euphonix MC Mix & Pro Tools LE, any user's? LaForestPoetry18 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 07-15-2008 03:37 PM
Pro Tools 6.0: Some Mac User's Disenfranchised!!! snapple 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 37 02-27-2003 09:20 PM
I need an experienced Schoeps user's opinion. Ricco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-01-2003 08:32 AM
Mac guy needs experienced PC user's advice... J. Guerrero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-17-2002 08:40 AM
