Go Back   Avid Pro Audio Community > Legacy Products > Digidesign Hardware & Software
Old 07-13-2016, 09:24 PM
Tonepicker Tonepicker is offline
Default Digi 192 expansion question
Ok I currently have a 192 with 2 analog input cards equaling 16 analog inputs, 1 analog output card for 8 outs, and a digital card that I never use! Can I pull out the digital i/o card and put in another analog output card giving me 16inX16out analog? Or will I need another 192 to acheave 8 more analog outs?
Old 07-13-2016, 09:35 PM
Default Re: Digi 192 expansion question
No. Configuration options/allowable cards in expansion slots are clearly explained in the Digidesign 192 IO Guide. PDFs easily findable online.
You need another chassis, or go to a HD IO (which can do 16x16 analog, and cards are not compatible), or use the ADAT Out on your digital card.
Old 07-13-2016, 10:05 PM
I was wanting 8 more outs for analog summing! Guess I'll find another 192... That'll give me the 8 more outs plus 8 more ins! Thanks man
Old 07-18-2016, 08:22 PM
For around $200, you could connect a Behringer ADA8002(the red version) with 2 lightpipes and gain 8 more inputs AND outputs via the digital ports on the 192
Old 07-19-2016, 12:09 AM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
No, AVID/Digi interfaces are 16 I/O max. ADAT is also limited to 48k (no SMUX).
A second 192 is a good way to go.
Old 07-19-2016, 10:45 AM
Connecting lightpipe out to the Behringer would get the OP 8 more analog outputs. If that's all he really needs, its much cheaper than a second 192(but I do agree another 192 will bring other advantages)
Old 07-19-2016, 09:26 PM
The other consideration for analog summing is that he'll experience comb filtering by mixing converters.
Old 07-19-2016, 10:40 PM
Or just give up, save time, money and hassle and mix in the box....
Old 07-20-2016, 08:45 AM
Yep. Engage HEAT and stay ITB. Works well and less hassle. I have an LFC that usually only actually runs as a monitor controller. Been a while since an album was actually mixed on it.
HTML code is On
Digi 002 expansion question delta macOS 4 02-16-2015 09:59 AM
7.4 with Digi Expansion HD bobo mark Pro Tools TDM Systems (Mac) 4 08-22-2008 08:53 PM
Another optical expansion question question for boffins Che_Guitarra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-23-2008 11:21 PM
Expansion for C8 >Digi>? dio ProControl, Control|24, Command|8 2 09-21-2005 11:50 PM
192 IO Digi expansion card Roger Stauss Pro Tools TDM Systems (Mac) 1 03-09-2005 06:27 PM
