Old 09-20-2020, 10:18 AM
rdpar's Avatar
rdpar rdpar is offline
Default 197 audio not where it should be?
Where did my audio go? I can automatically have them reloaded but, where are they, so I can put them back in my session audio folder?
Windows 10 Pro Tools 2019.6 Asus g752vt 17.3" laptop i7 Quad 2.6ghz 32gig ram
500gig ssd 2T ssd win. 10 Universal Audio x8P . Focusrite Clarett Octopre(NOT AN INTERFACE)
Old 09-20-2020, 12:04 PM
Default Re: 197 audio not where it should be?
Only you can figure that out. Where did these audio files come from? Imported from some external drive? Brought in as a full session from another PT setup? Recorded directly into the session you are opening? All these options( and more) can affect where the files reside. Assuming you can relink and get all the files to play, you could make a "working" version of the session by going to File>Save Copy in>check the box called Audio Files under "Items to copy" and save this to your recording drive as a separate session. Doing this will copy all the audio files into this new version, even if those files come from multiple locations.
If you set the Clips bin to show the full path name of the audio files(see photo), you can see exactly where they now are. If they are somewhere OTHER than your session file, that's the issue and doing the Save Copy as described above is a good fix. You do have other options, but that's the easy and certain method
Old 09-20-2020, 01:51 PM
rdpar's Avatar
Yup, you are so right. DUH! I just panicked. But , one day they were there and the next they weren't. I had been doing a lot of archiving my sessions and must have screwed that one up somehow. Thanks for the advice.
Old 09-20-2020, 05:13 PM
Glad you got it sorted! Most of us have made the same goof at least once or twice. Especially when someone brings a session in on a flash drive or external hard drive. There is a setting in Prefs to Always Copy Files on Import, and you should have that checked, but its still not 100% foolproof. Since getting bit a few times, my normal procedure is to copy the entire session folder onto my audio drive before opening. If its just audio files and not a session(maybe it was started on another DAW), I will copy them into the session folder I will create, and I will import from there(so if I screw that up, at least I know right where all the files are)
Importing audio files for remix - convert or set session to match source audio? LSW Tips & Tricks 22 09-09-2014 09:28 PM
Video - Bobby Lombardi, Audio Product Strategist for Avid Audio at NAB 2010 DTheone General Discussion 20 04-24-2010 06:53 PM
Audio Suite process puts new audio in audio bin Fritz12534 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-21-2009 08:55 AM
PRO TOOLS giving 2 Audio track ''Audio 5_02.L and Audio 5_02.R'' fredson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-20-2008 09:08 AM
USB2 Audio HD vs Fw Audio HD vs internal audio HD seth666 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 07-07-2005 02:06 AM
