Mojave 10.14 install
So far so good. I am running 12.4
IMAC 4 ghz Quad Core Intel i7. 512 SSD Internal + 512 external SSD drive for sessions. 32 gigs ram UAD 2 Apollo Quad core Pro Tools 2021.7 MAC OSX Big Sur |
Re: Mojave 10.14 install
At the risk of high jacking this thread... ALL Mac users should download this installer today (or within the week) even if they have no immediate or future plans of using Mojave.
Doing so will allow you to upgrade to any future Mojave dot version down the road should you at some point want or need to upgrade, re-install or downgrade a new machine (assuming that is allowed...). Once the 10.14.0 version is taken down by Apple, it will no longer be available - ever. Subsequent dot version updates will always be available. Having this installer as a saved backup will allow you to upgrade to whatever dot version is supported by your DAW even if that ins't the latest Apple version. mspin... thanks for the working upgrade notification!
Apple Mac Studio M2 MAX, 10 core, 96Gb RAM, 1Tb HD, macOS Ventura 13.4, Pro Tools 2024.3, AVID Omni HD, 2x AVID I/O, 1x HDX, Sonnet Tech Echo Express III-D (Thunderbolt 3 Edition), UAD-2 OCTO PCIe. |
Hey Quinn
Thanks for the info. Its been a couple of days since install and everything so far is good.
Thank you / it’s on a USB in my safe now! Sent from my iPhone using Tapatalk
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED! B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED! I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series! |
If you go through System Prefs and Updates, it will download and install, right? Can you just log into the apple store with your user name (and a registered product that allows you to download Mojave)? |
It has always been how things work, which is once it is downloaded it will run the installer. However, its not like it ACTUALLY installs since it requires several user selections to even actually start the install process, such as selecting which drive you want it go onto.
Mac Pro '09 - 5,1 - Dual Hex Core X5680 3.33 ghz CPU - 48GB RAM 970EVO 500GB (10.13.6) - 1TB WD Black HDD (Samples) - 6TB Toshiba HDD (Backups) - 500GB Glyph GT050Q (Legacy sessions & backups) - 3TB Glyph Studio (Main audio/sessions) HD5770 GPU OSX 10.13.6 - Pro Tools 2018.12 - Presonus Studio 192 / Digi 003 Rack+ Focusrite Clarett OctoPre - AKG HPE6 - DBX160A - WA76 |
Also Note for silver Mac Pro's "To install macOS Mojave, a firmware update is required."
Also consider this upgrade moves deeper into APFS Volume Format.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Mojave ? | Riquier | macOS | 89 | 02-26-2019 06:41 PM |
Mojave Audio MA 200?? | H-man | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-19-2006 08:19 AM |
Mojave Audio MA-200 | fasttraxx | Pro Tools TDM Systems (Mac) | 2 | 07-21-2006 03:59 PM |
OT: Mojave Audio (Royer) MA-200 | q0rban | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 07-22-2005 07:09 AM |
Mojave Audio mic - anyone tried one? | JSM | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 05-08-2003 02:49 PM |
