#31
Re: Pro Tools First 2018.7 Xpand!2 Presets Missing
#32
Does that mean you are now using the trial version of XPand2 instead of the free one that comes with ProTools First? Is there a difference?
#33
I'll give it a go later on so........... Here's hoping.
#34
It means that I used the files from the trial install and put them under the PT area. The PT license should override any that is used in the location for the Xpand!2 trial install, since they should be included anyway. They would have to have a license key on each .tfx file in order to control me copying the files. I'm pretty sure that is not the case.
#35
I also replied to my previous Avid case, so it is now up to them to do the right thing and fix it:
I figured this out on my own and wanted to make sure that Avid is aware that their Pro Tools First 2018.7 installer is not functioning properly. The .tfx files for Xpand!2 are either not included or not extracted properly. I had to figure out a workaround to get the files, even though they should have been included in the original install. This is a bug and should be fixed. Shame on Avid support for not even looking into this issue. |
#36
Is there any chance you can send me this Presets folder? |
#37
I need to check how large the files are it would be easiest for you to download them and install xpand from airs website. |
#38
in trying to find the preset location..... not sure if this will work.... but try creating and saving a preset in Xpanda and see where windows goes as its default location. then try searching for that location using "explorer" or whatever the Win search prg is. then try throwing preset file in there. Then open Pro Tools load Xpanda on a insert..... Locate and load the preset file via the Preset menu art the top of the plugin window Xpanda2 loads in.
Rob MBP 15 2018 macOS Big Sur 11.6.8 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II ........and a bowl of M&M's |
#39
#40
Awesome, nps
Presets missing from Xpand!2 | [email protected] | Virtual Instruments | 9 | 05-25-2019 01:20 AM |
Xpand 2 - missing presets? | TLK Tom | Virtual Instruments | 10 | 03-29-2019 09:49 AM |
PT 2018 Xpand2! Missing presets and disappearing MIDI input | Harleyman | Windows | 1 | 03-17-2019 02:30 AM |
Pro Tools First 2018.1 Missing EQ Graph panel | Jakeman | Pro Tools | Intro Discussion | 5 | 02-06-2018 08:00 PM |
