Old 08-16-2020, 12:13 PM
Maskeeper Maskeeper is offline
Default Timecode bug in v2020.5? Can you help me confirm?
For many years I’ve used the timecode selection function of pt by using the ‘/‘ key on the number pad.
Traditionally you could hit ‘/‘, type in a timecode. Hit ‘/‘ again type in the second timecode and hit enter and have a selection with those in/out points:
So previously I have been able to do:
01132212
01221213
"Enter"
And result in a selection from 01:13:22:12 to 01:22:12:13
However, currently when I try this: after typing in the first value and hitting the ‘/‘ to move on to the second value, the timecode I just typed as the START point is removed and the previous value is restored.
So if 01:22:01:07 is the current start point, I hit ‘/‘ and type in 01:00:00:00– I can see it in the start point counter but as soon as I hit ‘/‘ to go to the out point, the in point returns to 01:22:01:07.
The behavior has persisted through PT relaunch and System restart. I've tried Pref trashing. I discovered it while working in a 192 session so I tried a 48k session and the behavior was the same. I tried linking and unlinking the timeline/edit selection; no change.
I called a friend and confirm that this behavior was atypical (his worked fine, as I remembered it working) but he's running an earlier version. I confirmed with folks on a PT facebook group, work correctly, but again in different versions.
I'm just trying to figure out of 2020.5 is broken or I'm somehow in some terrible mode causing this.
VinceT.
Supervising Sound Editor - Los Angeles
Old 08-16-2020, 12:20 PM
Default Re: Timecode bug in v2020.5? Can you help me confirm?
As a strange side note, if I open the transport and click directly on the Start timecode in the transport window instead (since the "/" doesn't work to take you into the transport window) and type it in the timecode, I can then hit "/" and move onto the End timecode in the transport window and it works CORRECTLY (it keeps the value I typed in as the start value instead of resetting).
So then I verified in the 'main' timecode window, if I CLICK to select the Start (instead of using the "/" key) it still DOESN'T work correctly, and when I hit "/" to move to the end timecode, it loses the value.
So this function is working ok in the floating transport window version (although I have to click to access it) but it DOES NOT work correctly in the main timecode window, whether I select the START field by clicking or by using the "/" quick key!
VinceT.
Old 08-16-2020, 03:03 PM
SBP SBP is offline
Hi-Yes this is a problem. PT Ultimate PT2020.05 MAC OS 10.14.06
I think what is happening is when second press of / the value we enter as 'start' and expect to be fixed as 'start position' is changing to whatever the value is at that moment in the main counter.
So a work around to try;
= 'your start time' enter [this will become the start selection time]
then / / 'your end time' enter
This is very annoying as it is more keystrokes.
Are you able to raise a support case?
Cheers
Bruno
Old 08-16-2020, 09:38 PM
Originally Posted by SBP View Post
So the only work around is to use;
= 'enter your start time' [this will become the start selection time]
then / / 'to enter your end time'
Yeah, although you have to hit ENTER after inputting the timecode into the main counter (just hitting "//" after inputting without ENTER did nothing for me).
Honestly if I hit "/" and then enter the TC, if i hit ENTER after that works too-- then I just have to hit "//" to get back into the end input. Same basic idea; was trying to avoid the extra strokes.
Anyway, good to confirm it is in fact broken, I'll see if I can file a ticket with Avid about it.
VinceT.
Old 08-17-2020, 07:00 AM
Alden Manor Alden Manor is offline
I've submitted a bug report for this as well.
Didn't know if other people had the same issue.
First I'm hearing about it besides myself!
Old 08-17-2020, 04:20 PM
Is there another way to submit a bug report to Avid aside from opening a support case?
VinceT.
Old 08-17-2020, 06:46 PM
AndrewAction's Avatar
AndrewAction AndrewAction is offline
Yes. I sent you a private message yesterday asking what OS you are on. I have those details from the other two posters showing both Mac and Windows see the problem.
With the info I had this morning I brought this thread to the attention of a relevant person higher up so they would look into it.
Andrew
Old 08-17-2020, 07:28 PM
At present there are no cases in the Support system from this threads posters. Opening a support case ( avid.com/learn-and-support/contact-audio-and-music-support#Create-a-case ) is the best way to get things moving as it allows Avid to track the issue.
Andrew
Old 08-18-2020, 07:22 AM
originalscottyg originalscottyg is online now
I can confirm this behavior.
MacBook Pro 2019 2.3GHz i9 32GB
macOS 10.14.6
PT Ultimate 2020.5
HD Native TB
Omni
Scott Gatteño
Old 08-18-2020, 04:08 PM
I was advised by my Pro Tools contact that with 3 (now 4) confirming the issue that Avid should look into the issue and that the best way to get that process underway was to open a support case.
Have any of you opened a support case??
Andrew
HTML code is On
Pro Tools v2020.5 Now Available Avid Technical Alerts 0 05-27-2020 05:15 PM
Pro Tools v2020.3 Now Available Avid Technical Alerts 0 03-31-2020 08:21 AM
Video Timecode Issue, confirm I've crewed :) Monty_python Pro Tools 12 20 02-17-2016 08:53 AM
TimeCode to camera + TimeCode-led display with digi003 Fingerflipz Post - Surround - Video 7 03-18-2010 02:07 PM
smpte timecode to timecode dat from PT LE 6.2.2 shake 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 01-21-2004 01:16 PM
