Old 05-10-2013, 09:14 AM
mtung mtung is offline
Default Does anyone make an SSL 4K channel strip AAX DSP?
Not native. DSP.
I want the convenience of a channel strip that's been part of my work flow for years and the low latency of DSP. Can't seem to find one.
Does anyone make one or planning on making one?
I have learned so far that Softube has a UK4K but you have to buy the controller to get it. Waves is AAX native only. And all other solutions seem to need more hardware which causes more latency.
All tips are appreciated.
thanks
mike
Old 05-10-2013, 11:36 AM
Drew Mazurek's Avatar
Default Re: Does anyone make an SSL 4K channel strip AAX DSP?
DSP Channel Strips:
McDSP G Channel
Metric Halo-Channel Strip
Softube Grand Channel
Softube TubeTech CLassic channel
Avid's Channel Strip.
That's about it.
www.drewmazurek.com
Old 05-11-2013, 12:13 AM
JFreak's Avatar
JFreak JFreak is offline
I'm hoping Waves will eventually find their lost brain, but currently things do not look that great.
Janne
Old 05-11-2013, 05:10 AM
Emcha_audio's Avatar
Slate digital VCC has one in it but it's native also.
Manny.
Wave-T.com
Old 05-11-2013, 08:12 AM
nst7 nst7 is offline
Keep in mind that the Slate VCC is only the sound of running through the SSL channel, not the EQ or compression.
Old 05-11-2013, 09:31 AM
CME CME is offline
I believe Cytomic's the glue is suppose to go AAX DSP. That'll get you the compressor. I'm sure someone will come out with an SSL DSP channel strip.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 05-12-2013, 08:30 AM
Yes, been using the WAVES SSL and that works great with the Dcommand but Waves not having AAX DSP has got me evaluating that whole situation. So, as soon as a suitable DSP version comes out, I'll be happy to try something else.
m
Old 05-12-2013, 11:47 AM
Bill Denton Bill Denton is offline
m
Waves will have an AAX DSP version...it just won't be an HDX version.
Waves will be using a separate DSP box, much like Universal Audio's architecture...
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 05-12-2013, 03:42 PM
Hi Bill!
I got the same advice from Waves that I should consider their new hardware. However, I'm trying to keep the latency down to a minimum and an extra 32 samples is a step in the wrong direction for my work flow, especially tracking bands. I know that not everyone's needs are the same. No biggie though. I feel confident that someone will come and fill the void.... sooner or later. If you hear of anything interesting, let me know!
Thanks!
mike
Old 05-12-2013, 11:58 PM
treason treason is offline
Hi Bill!
Thanks!
mike
I'm with you Mike. Waves should release their SSL and API bundles AAX-DSP before someone else takes that spot from them. But if they don't, I'll follow the new leader.
T-
Waterstreet Studio Main: MacPro 2012 ([email protected]), 48GB, Apple/Samsung SSDs, WD Blacks. macOS 13.3
DSP & IO : Pro Tools HDX2(2018.3), 2x UAD Octo, HDIO 16x16 Analog IO(3), HDIO 16x16 Digital IO
Plugins: Avid, DMG Audio, Kush, oeksound, P'n'T, Plugin Alliance, Softube, SoundTheory, Sonnox, Sound Radix, SoundToys, UAD, VEP, etc
Hardware: API, Chandler, Hardy, Moog, Neve, Shadow Hills, Smart, Summit, TC Electronic M6000, UREI, etc
Microphones: Telefunken, Neumann, Shure, AKG
HTML code is On
Using a Channel Strip bcarrancho 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-30-2011 03:14 AM
Renaissance channel vs Channel Strip frenchman Tips & Tricks 1 09-20-2003 05:18 AM
HELP ME! Need to make SMPTE STRIP W/ PT LE Alfeo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 10-02-2002 12:00 AM
DBX 376 Channel Strip Yah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-07-2002 12:01 AM
Channel Strip and 5.1 nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-16-2001 02:40 AM
