Here's a good one...
I tried clip effects on a guitar solo this AM with good results. After an hour I tried it on both another newly recorded track and the same guitar track (different clip). Couldn't set anything, clicked everywhere and couldn't adjust ANYTHING. Quit PT - trashed prefs and rebooted. All good. An hour later try on different clip in same guitar track.. can't adjust anything. Not only that but I copied the one I had done earlier in the day (same low mid resonance) and although it appeared there (showed Eq curve) nothing was being applied. Do tell me AVID what I'm doing wrong. Carl
PT 2020.12.0 HDX OMNI+HDX8x16 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
Check to see if you are trying to apply clip effects to a set of grouped clips. If the clips are grouped use opt-cmd+u to ungroup them…
I ran into the same problem.
www.chrisshawmix.com PT 20.3.0 S1 Artist Transport Avid Control iPad 7th Gen HD Native Hackintosh i9 3.6 GHz Six Core Apogee Ensemble OSX 10.13.6 |
No clips are grouped. Not a one..
This is happening on newly recorded tracks with just one edit in the whole track. C
Same problem here and no Grouped clips. Some EQ and Dynamics graphical controls available, but rest is frozen. Restarting helps. Did clean re-instal and problem persists. Haven't noticed, what could cause this. Pretty annoying when you are in hurry. Anyone experiencing this as well?
x form rendering blank files when choosing clip by clip audiosuite | dj_grimmace | AAX Plug-ins | 2 | 06-21-2017 12:29 PM |
x form rendering blank files when choosing clip by clip audiosuite | dj_grimmace | Pro Tools 11 | 1 | 03-04-2017 01:35 PM |
Clip Effects - Compression Metering?? | off the wall | Pro Tools 12 | 8 | 09-30-2016 10:59 AM |
Clip Effects Enabled by default | cshaw | Pro Tools 12 | 0 | 09-30-2016 09:52 AM |
Clip effects not working [SOLVED] | cshaw | Pro Tools 12 | 5 | 09-30-2016 06:22 AM |
