I've been using the clip effects on a bunch of small projects and its a great feature however;
1-be cool if bypass was the default -ie All clip effects default to an 'inactive' state. 2-I find the processing state visual impossible to read when I have lots of tracks or am zoomed out [Or when I am at the start of a clip that extends longer than the edit window] -a band or something around the clip would be clearer. It would be great to have the processing state display in edit window much clearer. 3-It would be great if clip effects were included when you export a 'clip group' 4-I find myself selecting a clip in the edit window then going to the clips bin and selecting "object select in edit window" often. -this is so that all of the 'other same' clips used in the timeline get the new settings -however the time line then plays from the first clip (unless I unlink the track and edit timeline selection) I find this clunky -it would be good to streamline the option to "edit clip effects for all same clips used in timeline" or "edit selected clip only" -I can see a bunch of easy ways to do this -perhaps a selector where the clip name is. Just my thoughts thanks for the useful addition. All the best Bruno Last edited by SBP; 06-12-2017 at 06:48 PM. |
- Jesus Alvarado - Keep the volume UP ! ![]() |
Disable Clip Effects | markuse_23 | Pro Tools 12 | 0 | 01-31-2017 04:06 AM |
Cannot Edit Clip Effects in PT 12.6 HD | conleec | Pro Tools 12 | 81 | 01-30-2017 08:55 PM |
What's so special about clip effects? | Darryl Duncan | Pro Tools 12 | 22 | 10-25-2016 10:11 AM |
Clip Effects Freezing | Carl Lie | Pro Tools 12 | 3 | 10-05-2016 05:24 AM |
Clip Effects - Compression Metering?? | off the wall | Pro Tools 12 | 8 | 09-30-2016 10:59 AM |
