Old 08-02-2010, 05:05 PM
defiance defiance is offline
Default Digidesign 003r adat to presonus 2626
can i use the pre's on my presonus in protools (just to expand the number of inputs)
how would i do this?
Old 08-02-2010, 05:22 PM
DigiTechSupt's Avatar
DigiTechSupt DigiTechSupt is online now
Default Re: Digidesign 003r adat to presonus 2626
Set the Presonus to standalone mode and connect and ADAT cable from it's optical out to the optical in on the 003. In Pro Tools Hardware Setup set the optical port to ADAT and the clock source to ADAT.
You may need to default your IO Setups to get the ADAT input ports to show up.
I believe the Presonus has an optical input as well, so if you wanted to clock the Presonus to the 003, you would need to connect an ADAT cable from the optical out of the 003 to the optical in on the 2626 then, instead of setting the 003 to clock to ADAT you would leave it set to internal and set the 2626 to clock to the optical ADAT input.
Avid Audio Tech Support
Support FAQ
so, on the table.... 003R or 2626 or ......? 440Hz Pro Tools 9 7 12-02-2011 12:40 PM
PT 9.0.3: OSX 10.6.8: Presonus Firestudio 2626: ISSUE Ryan Young macOS 1 09-02-2011 01:53 AM
Linking 003R & 2626 via ADAT Jrestes927 Windows 1 04-13-2011 02:28 PM
Profire 2626 ADAT to 003R LE 8 Ph.D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-07-2010 11:04 PM
MBox 2 Pro → Profire 2626/003R+!? Is it good or bad? Which is better? UltraNEO* 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 05-22-2009 04:57 PM
