Old 09-04-2019, 05:19 AM
HFX HFX is offline
Default EUCON Faders Off Command...
When using the Faders Off Command assigned to a key on the S3, it just turn off the S3 faders and sets them to ∞. If I then accidentally touch a S3 fader it will set the fader in Pro Tools to ∞ as well and silence the channel. So in reality it's just the movement off the fader that is off, not the touch function.
Is there a workaround for this behavior?
Hans
Old 09-04-2019, 08:31 AM
BScout BScout is offline
Default Re: EUCON Faders Off Command...
There are two commands to turn off faders: Faders Off and Suspend All Faders.
Faders Off is a Euconized command and can be put on a softkey on the Control App. You've seen what that does.
Suspend All Faders is a toggle switch in Eucontrol > General tab (look at the left column, a little lower than 1/2 way down.) This is the one that actually suspends the faders from sending commands.
Unfortunately it is not Euconized yet so you can't put it on a soft key.
Old 09-04-2019, 08:41 AM
HFX HFX is offline
Thanks for the info!
All the best / Hans
Faders off Eucon command not working Led Artist Series 4 07-24-2016 05:39 PM
Command 8 and Eucon cananball Artist Series 1 01-08-2015 02:59 PM
FS: D-Command ES 24 Faders / like new Numarek Buy & Sell 0 04-30-2013 06:12 AM
D-Command... faders only possible? Hardin ICON & C|24 2 11-21-2011 01:58 PM
002 and Command 8 faders (not together) Bixby 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-22-2004 08:17 PM
