Any solution to random "Calculating Overviews" nuisance?
We've been running into the issue where sessions have to "Calculate Overviews" when opening. Happens even when we JUST had the same session open.
Sessions are on an ISIS volume. Media is on ISIS as well. Content comes from an AAF referring to source media. Seems to be completely random. Sometimes the same session will open WITH overviews intact. The next time it will have to calculate, which takes up to 5 minutes and Protools is almost un-usably sluggish for the duration of "Calculating". |
Re: Any solution to random "Calculating Overviews" nuisance?
Just a quick bump while I'm watching the progress of the overview calculating in the task manager for a session I JUST CLOSED AND REOPENED! Which I had to do to be able to HEAR the noise reduction I did to a 1 second clip with Izotope RX (different discussion).
This is the downside to working with MXF audio media.
Are any of your tracks set as a "Production Audio Guide Track"? Since you are using shared storage on a ISIS you probably cannot "Save Session copy In" and create a WAV only copy of the session, Although that would solve your problem. Also make sure you are using the latest build of Ptools, 10.2 MXF wrapped media still does not play so great with ptools. |
Slow opening sessions "Reading Track Overviews" | russ russell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-03-2011 07:08 PM |
HELP: PT8 M-Powered hangs during "reading overviews" | dartveiga | Pro Tools M-Powered (Win) | 7 | 09-07-2010 10:16 AM |
"calculating overviews" wait, wait, wait | rtcstudio | Pro Tools M-Powered (Mac) | 5 | 06-16-2009 10:32 AM |
Freeze on "Reading Overviews" | Bombhash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 03-02-2009 10:12 AM |
New "digital"Neumann mic "Solution -D"!!!! | Robert U | Tips & Tricks | 0 | 08-05-2001 11:58 AM |
