Pro tools LE stops at \'setting up peripherals\'.
I just bought a mac mini (2gig proc 1GB ram )with an Mbox 2. I downloaded 7.4.2pr and am running Leopard 10.5.3. I clicked on the LE icon and pro tools loads up to the point where it says 'setting up peripherals'. Then the loading screen disappears and that's it. If I click on the icon again it's as if the program is already running. I can Quit out of it by right clicking and load it again but the same thing happens.
I did the combo updater from apple I clean uninstalled like 5 times. i searched the Forum but couldn't find a similar issue There are no 3rd party plugins installed I tried removing the existing plugins I hope i'm just retarded and am missing something obvious. Any help would be awesome. thx - rob |
Re: Pro tools LE stops at \'setting up peripherals\'.
Have you done the other stuff in the problem shooting thread? Repaired disk permissions, tried from another user, removed all peripherals, and so on?
Is the splash screen still on? I.e; does it stay at the progress bar 'Setting up peripherals'? I had that problem sometimes when my harddrive was mounted while launching pt mp.
I just wanna do engineering... (as opposed to make music :/ ) |
Trash your Prefs, reboot,reluanch
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
Re: Pro tools LE stops at 'setting up peripherals'.
I acutally did what SunBurt79 recommended and still have the problem.
I really can't get rid off it. in the trouble shoothin thread I haven't foudn anything so far. any help? |
Drop any external firewire or USB drives that are connected to the computer. Restart, and then try to launch again. Hook up your drives after pro tools is launched and running. See if that helps.
i was seeing this as well - even without usb or firewire drives connected. it's either a specific usb cable or my powered usb hub or both? connecting my mbox 2 to my imac with another usb cable works.
are the leds (mic, usb) on your mbox 2 on? |
Procontrol faderpack shows up as main unit in peripherals ID setting ? | digigirly | ProControl, Control|24, Command|8 | 3 | 05-05-2013 02:14 PM |
PT LE 7.4.2 stuck in setting up peripherals | crazy_urn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-16-2012 02:46 PM |
9.0.2 crashes when setting up MIDI peripherals? | tblythe.sound | macOS | 3 | 06-02-2011 09:38 AM |
PT 7 start-up Freezes at "setting up peripherals" | guitates | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-20-2006 06:51 AM |
Trouble setting up peripherals (no interface?) | JimZad | Pro Tools TDM Systems (Mac) | 11 | 08-24-2004 03:16 AM |
