Old 08-29-2009, 01:32 AM
nerwrak nerwrak is offline
Question Pro Tools on Macbook Pro, enough power?
I've just bought a MacBook Pro, 2.66ghz.
Is it powerful enough to run Pro Tools LE with it?
You know, with maximum of audiotracks and instrument tracks with the software synths, plugins and so on.
Can it handle heavy audio processing?
Old 08-29-2009, 03:08 AM
amolin amolin is offline
Default Re: Pro Tools on Macbook Pro, enough power?
I have no problems with mine. I always freeze the instrument tracks though, but I have been mixing sessions with 40+ audio tracks with all sorts of plugin's without problems :)
Old 08-29-2009, 06:21 AM
DonM DonM is offline
I'd say the answer is yes and no. It depends on how 'much' you need. I am running PTM and PTLE on MacBook Pro's - They work for some of my projects - mostly post and small format recordings (4 to 6 tracks in at a time). I do large format orchestra recording for NPR - I need typically 16 tracks in at one time - PT on my Mac Books won't do that. So the MBP with a digi or M-A interface works great for the right sized projects.
I'd suspect that if you need a lot of plugs and tracks - you'll begin to find ways of working within the power available to you. PTLE can do a lot. Your job as the engineer is to learn it's boundaries and become creative with the tool.
I use Pro Tools, Samplitude, Sonar and Reaper and other tools in my work. I am always learning what can and can't be done on each. In fact, I am preparing for a 14 to 16 channel live orchestra recording this week - I will be using a Mac Book Pro - but running BootCamp XP32 with Samplitude. I don't have an on-location interface for PT with 16 ins. I will post that project in Pro Tools when we return to the studio. Again PT on my MB is perfect for that.
-D
Old 08-29-2009, 01:53 PM
se.audio's Avatar
se.audio se.audio is offline
You'll be fine... might have to make some compromises at the end of your sessions when it's runing full blown with VIs and tons of track, but for most projects you'll be good...
Old 08-30-2009, 02:06 PM
mixer mixer is offline
works perfectly well.. using it right now..
www.garyvandy.com
Old 08-30-2009, 03:36 PM
The Dougfather The Dougfather is offline
Are you recording to an external FW drive, sixteen tracks at once should be easy?
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 08-30-2009, 11:43 PM
CME CME is offline
My MacBook Pros rocks for PTLE. The wall you may run up against is with VI's. I don't' use too many but usually end up with Strike, a couple Hybrids, and even an Xpand or 2. Add to that 20+ tracks of audio with at least an EQ on each channel, probably a compressor on most, and various other plugs used as needed. I've yet to max it out. I am diligent about making sure I have compatible plugs, and all my VI's are Digi ones. That seems to help.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 08-31-2009, 12:54 AM
tamasdragon tamasdragon is offline
Macbookpro here with live rec at 32buffer, 16-18 tracks recording, with a few plugins in the headphone mixes, absolutely flawless.
Tamas Dragon
my blog:Tamas Dragon
Old 08-31-2009, 02:33 AM
Thanks for the quick answers! :)
Old 08-31-2009, 05:56 AM
brendanJacobs brendanJacobs is offline
Same situation as most above. MBP, PT8 LE, 20 tracks +. I'm smiling.
pro tools m power compatability with macbook AIR 21m Tips & Tricks 2 08-29-2011 02:00 PM
Pro tools gone haywire!! macbook power? tribedescribe macOS 6 08-17-2011 03:36 PM
Macbook wont power my M-Box ValdiCBU 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-02-2010 12:36 PM
Macbook power to G5 PTLE buckaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-14-2008 01:46 AM
Macbook won't power the Mbox 2 dokno 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-01-2007 10:52 AM
