Go Back   Avid Pro Audio Community > Pro Tools Software > Licensing & Accounts
Old 09-29-2016, 10:58 AM
3peacestudios 3peacestudios is offline
Default 12.6 Not Recognizing HD Native / Avid HD|IO
Trying to get 12.6 working today. Jeffo put a temp license in my ilok account and Protools seemingly boots, but the hardware isn't being detected. The only option in hardware is display audio. HD Driver 12.6 was installed. The HD unit clicks when the software boots or when I go to the hardware page, as it normally would. What am I missing?
System:
HD Native
HD IO
Lavry 4496 hooked up to digital in's and outs (1&2)
Big Ben running clock
Mac Pro 2010 5,1
OS 10.11.6
PT 12.6
Thanks
Old 09-29-2016, 11:09 AM
Drew Mazurek's Avatar
Do you have a DIgilink I/O iLok authorization in the bundle?
www.drewmazurek.com
Old 09-29-2016, 11:11 AM
Bart HLH Bart HLH is offline
Default Re: 12.6 Not Recognizing HD Native / Avid HD|IO
I have the exact same problem on a HDX system with temporary license...
Did not receive the DIgilink I/O iLok authorization
www.highlakehill.be
Old 09-29-2016, 11:32 AM
I've alerted Jeffro.
www.drewmazurek.com
Old 09-29-2016, 12:00 PM
jeffro's Avatar
jeffro jeffro is offline
You both should be set now (at least with temps).
linkedin
Old 09-29-2016, 12:43 PM
Thanks for the replies. I actually did have the DigiLink I/O temp auth in my ilok, I had activated it.
Old 09-30-2016, 12:35 AM
Thanks! I'm up and running (with temps)!
www.highlakehill.be
Old 09-30-2016, 09:35 AM
psyrico psyrico is offline
Hi!
I'm having the same isue. I just installed 12.6 hd and have surrendered and activated everything but nothing, no hd interfaces (avid 8x8x8) show up.
How did you fix it and who is Jeffo ;-)
/Ricardo
Old 09-30-2016, 10:25 AM
I haven't gotten mine to work. I tried rolling back to 12.5 driver and "tried" installing 12.5 software again. I say "tried" because 12.5 wouldn't overwrite 12.6, so I just deleted 12.6 and installed 12.5 and accompanying driver. Unfortunately, that didn't work either, so I am scouring the inter-webs for a hopeful (read:hopeless) solution. I am likely going to just rollback my OS backup from time capsule from before this all started.
I tried deactivating and reactivating the temp licenses Jeffro got me, but nothing seems to work. Protools clicks the AVID I/O when it's booting or when I go into the hardware menu, but it doesn't show up. It doesn't show up in the Apple Audio MIDI setup either, not sure if it used to or not, but I thought it did. At any rate, I have to believe this is a driver issue.
Luckily, I have learned my lesson with Avid's little updates and I attempted this while I didn't have any pressing session work, so I am not completely stressing about it.
Old 09-30-2016, 01:36 PM
jeffro's Avatar
Originally Posted by 3peacestudios View Post
...the hardware isn't being detected. The only option in hardware is display audio. HD Driver 12.6 was installed. The HD unit clicks when the software boots or when I go to the hardware page, as it normally would...
Started a support case on your behalf to get a tech to troubleshoot.
linkedin
Pro tools 12 not recognizing HD Native card alex.nealex Pro Tools 12 19 12-21-2015 07:39 PM
PT HD 10.3.9 not recognizing Native HD card resonate Pro Tools HDX & HD Native Systems (Mac) 5 12-22-2014 10:00 AM
PTHD 11 native not recognizing my omni I&I Pro Tools HDX & HD Native Systems (Mac) 6 09-09-2013 07:50 AM
Pro Tools 10 No Longer Recognizing HD Native Thunderbolt TonyBuenger Pro Tools HDX & HD Native Systems (Mac) 3 02-22-2013 08:03 AM
HD Native not recognizing 192 IO saltyfrank Pro Tools HDX & HD Native Systems (Mac) 2 03-21-2011 05:47 PM
