Old 06-29-2012, 08:54 AM
Raoul23 Raoul23 is offline
Default Dly red in Pro Tools 10HD??
Im Running asession in pro tools HD ADC is set to long and i have the Dly in the mix window going red (see image below) but ive not exceeded the limit and when i hover above it it doesnt tell me anything even though ive got the tips active.
http://www.freeimagehosting.net/6u36f
Ive found if i make VTM and duy wide inactive the DLy goes green (see image below)
http://www.freeimagehosting.net/tsqrf
on my sub mix the other plugs are running DSP while these are running native as they dont come in DSP
Has anyone got any ideas about this?????
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 06-30-2012, 07:53 PM
Default Re: Dly red in Pro Tools 10HD??
Is there a track showing red at the bottom(where latency is shown in samples)?. If yes, what plugins are on that track? If no, maybe one of the plugins you mentioned is not reporting latency correctly. That could be an Avid issue, but more likely a bug with the 3rd party plugin.
Old 07-01-2012, 07:02 AM
That's the strange thing no channel is Red and it's only when ever I put a native plug on not TDM. This is the channel with the most latency as its orange so I'm not sure what's happening ?
Raoul Crane
Old 07-01-2012, 07:13 AM
BobbyDazzler's Avatar
BobbyDazzler BobbyDazzler is offline
Do you have any Tracks or Auxes assigned to inactive outputs?
I would get red Dly indicators from that sometimes.
HP Z2 Xeon 6 Core, Blackmagic Decklink HD Extreme 3D Win10, PT ver.. Latest
Old 07-01-2012, 07:19 AM
I don't think do but I'll check that tonite when I'm back in the studio
Raoul Crane
Old 07-01-2012, 11:49 AM
DJ Hellfire DJ Hellfire is offline
It's orange in your picture, not red. Orange means that's the highest delay track/s. Green ones are the ones being compensated to match the tracks with latency.
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 07-01-2012, 12:24 PM
Yeah so if it was over the ADC limit it would be red causing the DLY indicator to be Red??????? But this is not the case
Raoul Crane
Old 07-01-2012, 12:45 PM
Exactly. I mean, the compensation in 10 can accomodate over 16,000 samples of delay. I've never seen a plugin that is causes that much. Most I seen is a little over 8,000 samples. Looks like you're fine to me. You can even put on Short and save some resources until you come across tracks that go over 4000 or so samples of delay!
Can you post a screen shot of the whole mix window when it's doing the problem you are mentioning?
Pro Tools 2021.12
Old 07-01-2012, 12:56 PM
I can do when I'm back in the studio. But DLY at the top of the edit window goes red whenever I activate a native plug on the submix if I put a TDM plug there it's fine I can't hear any problem I'm just curious why it goes red but the latency is only orange?
Raoul Crane
Old 07-01-2012, 08:35 PM
WernerF WernerF is offline
You guys are forgetting the fact that the Native delay comp numbers for 10 are different and much higher than the HD TDM numbers. Also, don't forget that tracks that have multiple delay inducing plugins on them that are being sent to an aux track through sends will rack up high delay numbers on the aux track.
Pro Tools 10HD and 5.1 clunystudios macOS 7 01-07-2014 05:43 AM
Does Pro TOOLS 10hd WORK WITH USB MIC? PT10user101 Windows 47 03-24-2013 11:45 AM
Pro tools 10 to 10HD? djmichaelwenz Pro Tools 10 3 09-15-2012 10:04 AM
FS Pro Tools 10HD bundle Raoul23 Buy & Sell 5 08-27-2012 01:41 PM
HD Native and Pro Tools 10HD zion Pro Tools HDX & HD Native Systems (Win) 8 11-04-2011 08:08 AM
