CPU Overload 6101
Hello
I am having the same problems as a few of you, thought I'd better start a new thread to increase the chances of DIGI looking at this. I am getting constant 6101 errors My set up is this: Macbook Pro 2.8 GHz, 4gb mem, OSX 10.6.5 PT M powered 8.0.4 cs2 Mackie onyx 1620i using latest firmware (1.05.00129) connected via FW800 port to FW400 V1.0.4 Mackie Universal Driver iOmega HDD1H4-2 connected via FW400 PCI card I've tried all the general set up stuff, I've deleted the launch deamon and system pref for elevenrack. I was running with a projectmix i/o which was running intermittently, but it packed in so had to switch to the onyx. I got Reaper running fine, but cannot use BFD for some reason! I am hating computer recording right now - everything seems so flaky! I will try and post the log files.... |
Re: CPU Overload 6101
Error suppression is on, by the way....
Turnin error suppression off and upping the H/w buffer seems to have done the trick - now got mixdown problems - the mix is coming out slow - AARRRRRRRGGGGGHHHHHHHH. will start a new post...
CPU Overload -6101 | wiggity5050 | Pro Tools 10 | 4 | 01-04-2014 04:10 PM |
6101 CPU Overload | Jeroen.Kox | Pro Tools 10 | 4 | 12-17-2013 03:27 PM |
CPU Overload (6101) | foxdog175 | macOS | 17 | 10-26-2012 10:18 AM |
(-6101) CPU Overload Error | CujoAC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 29 | 07-04-2008 11:20 AM |
-6101 CPU overload | bad_ben | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-26-2007 04:53 PM |
