Undocumented keyboard shortcuts
Someone mentioned option-A as the equivalent of the now-dissappeared double-tap on F5 in order to have the whole session hove into view. I can't find this option-A in any of the documenation. What other hidden gems are there?
Re: Undocumented keyboard shortcuts
option A = dbl tap F5!!! thank god i have miss that.
(-) key next to the zero at the top of the keyboard toggles between waveform and volume graph. Option and (-) key toggles all tracks.
Ctrl + any numeric keypad number plays back individual tracks at varying speeds. 5 is exact speed, and anything above 5 is faster, anything below 5 is slower.
-Guruman |
Option-(-): thats a good one! I'll definitely use that.
I recently started using the "enter start/end/length" and its neighbour, "enter main counter" a lot. Command key focus is a godsend. |
We all know that you can hold 'Control' to temporarily scrub while in waveform view. Is there any way temporarily scrub in volume or Pan view? (It's a pain to switch to the scrubber for 2 seconds just to see where you are and then switch back)
This used to be do-able back in 4.x
Thomas Anthony Natural Sound |
here´s another one:
"§" (on the left side of "1") means "select unused regions except whole files"! i never found any documentation about this shortcut. and: num-lock opens clear audio dialogue so that´s my personal sequence: §-num-enter kp |
In Search Of: Undocumented Pro Tools 10 Shortcuts | Rufio | Pro Tools 10 | 14 | 01-13-2013 09:09 PM |
A-Z keyboard shortcuts for GROUA-Z keyboard shortcuts forPS in the SECONDS ID group.. | jessedtf | Pro Tools 10 | 6 | 10-24-2012 09:42 AM |
Keyboard Shortcuts-Apple Thin Keyboard | Brian in Charlotte | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-15-2008 03:17 PM |
Undocumented shortcuts | tj_davies | Tips & Tricks | 4 | 11-01-2007 12:07 PM |
keyboard shortcuts without an Apple keyboard? | doublestakked | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-22-2006 05:04 AM |
