Old 03-07-2024, 09:11 AM
Patill Patill is offline
Default Installation Set Up /split for ProTools and Plugins on a new Mac Book Pro
Hello,
I just bought a MacBook Pro with M3 Max Chip and 36 GB RAM. I wonder if you still have to consider splitting installation /recording locations like you had to when using HDDs.
When installing ProTools and PlugIns like East West Symphonic Orchestra, what would be the best way to install those? Do they all go on the internal SSD or should I use an external SSD for PlugIns?
Same thing for recording? Macs are pretty capable these days (my old one is from 2008), Iīve always been recording to a separate SSD since it was recommended for HDDs 20 years ago I wonder if itīs still the case to split paths.
Thanks.
Old 03-07-2024, 09:22 AM
Default Re: Installation Set Up /split for ProTools and Plugins on a new Mac Book Pro
Second question:
I usually wanted to avoid switching versions, since everything is in the range of compatibility at the moment...Iīve been using ProTools 2019.6.0 all the time but now it says that it would need Rosetta to boot.
Is it worth to buy the latest PT version to use it with the Apple M3Max Chip?
Really sorry for these stupid questions. Iīm upgrading my gear about every 10 years, dealing with compatibility issues you really donīt want to face...I really hope this will be the last time to upgrade before I die when Iīm done here I'll just leave everything as is (and not bothering you with this) and will die in peace after a loooong time of fun
Old 03-07-2024, 10:06 AM
All this stuff has been discussed to death on many threads on DUC. You should be using Google to find stuff with the site:duc.avid.com qualifier. And this stuff should have been worked though before getting your new Mac.
You need to be on 2022.12 or later to get native Apple Silicon support (vs. running under Rosetta, get on native). I would get on the latest PT release. Including maybe if you have time to check stuff out, the new release that is likely to drop soon.
You should be aware that currently Sonoma is not supported, although many of us are using it. Be aware of the known issues: https://avidtech.my.salesforce-sites...tibility-Chart
You need to look though all your plugins and make sure they are up to date and have native Apple Silicon native AAX ports (not just fuzzy claims of "compatible" with Apple Silicon). You may need to purchase upgrades to get on versions with this. Use Pete Gates' PT Pref tool to scan plugins and see what ones you have are x64 only or Universal (x64 plus Apple Silicon).
With super-fast internal PCIe/NVMe (and separately disk cache if used) there has not been any need to separate disk usage for a decade or so now. You can put everything on the internal SSD, OS, session, samples. And doing so is often better/faster than moving some of that to slower, and in some cases stupidly slow, external drives. The decisions are largely how much space there is on the internal SSD and your preferences in how things are laid out for convenience, maybe portability, or backup/recovery reasons. But the driver here is *not* some old dead rule that no longer apples, and can do more harm than good. I have long encourage folks to pay the extra Apple SSD tax and run as much as possible internally. Especially for portable/transportable use I want to avoid less reliable external HDD/SSD connections.
And if you do put stuff on external SSD, buy quality SSD drives (esp. from Samsung) and you have responsibility to manage these properly, starting with checking the bloody firmware is up to date: https://duc.avid.com/showthread.php?t=425632. And if you want fast external SSDs that are within close multiples of the internal SSD performance you need PCIe/NVMe SSDs in Thunderbolt docks or expansion chassis and that can be some work to set up depending on what you want to do. Most folks don't *need* this fast PCIe/NVMe external storage, but I love having lots of that available.
Old 03-07-2024, 10:11 AM
And 2023.4 just dropped with official Sonoma support. As with any new release you should watch DUC for the next weeks for reports of issues. But I'd suggest just getting on that while you sort out plugins and other stuff, you can always roll back Pro Tools.
Old 03-07-2024, 10:36 AM
Tweakhead Tweakhead is offline
The Avid "all documents" link leads to the old version.
Here is the correct link for 2024.3 Documents:
https://resources.avid.com/SupportFi...3_Docs_ALL.zip
Old 03-07-2024, 11:19 AM
marianna's Avatar
marianna marianna is offline
Might be because the deployment is not completed yet.
We are checking.
Marianna
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
Old 03-07-2024, 11:37 AM
Thanks for this in depth explaination. Really great. By this quote you mean the 2023.4 release you mentioned or is there going to be a new one, soon?
I will update my Plugins one again then...seems itīs not gonna bee too much this time, since Iīve already done it last time.
What I couldnīt find is the Silicon Support for East West Symphonic Orchestra, their website doesnīt seem to give valuable information. Iīll contact them and hope itīs gonna work.
Old 03-07-2024, 12:03 PM
I meant 2023.4 that is rolling out right now.
Make sure you have the latest free PT Prefs 2 app from Pete Gates and just run it now and check for any x64 only plugins. Learn how to use it *now* to look at plugins. It also gives you plugin versions that might help you check if you have the latest from different vendors, but either way check that as well. But the single most important thing you can have is PT Prefs 2 and if plugins don't show up for you in Pro Tools on Apple Silicon the first thing to do is check them with PT Prefs 2.
There are multiple threads on DUC about native silicon plugin support esp. this one: https://duc.avid.com/showthread.php?t=415770&page=82 I am sure EW has been mentioned many times on DUC, and it's pretty clear on their website they support Apple Silicon on Opus. So you may need to upgrade, but I'm not an EW user, would not know their stuff if it bit me, you can search around yourself for more info.
Also note and tables of supported plugins on Avid (https://avidtech.my.salesforce-sites...-Compatibility) and on Production Expert (https://www.production-expert.com/ap...tibility-guide). Both lists are useful, and both have issues, so if in doubt confirm stuff ideally with vendors and always by checking with PT Prefs 2.
Old 03-08-2024, 06:46 AM
Just to clarify, it's 2024.3, not 2023.4.
Scott Gatteņo
Old 03-08-2024, 07:28 AM
smurfyou smurfyou is offline
You can split your internal drive with a separate Volume for your VI samples etc... It's like an easy virtual partition. It shows up as a separate drive but the space is shared dynamically. I like it because it keeps things organized how I like and it also helps me segregate the backups between system data and "other".
~Will
PlugIns installation not loading into PlugIns menu in PT hannahjazzz macOS 6 02-22-2019 12:19 PM
controlling plugins on split stereo material cananball Post - Surround - Video 4 12-19-2011 06:28 PM
Step by step procedure for installation on new Mac Book Pro velectrocity 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-23-2010 12:00 PM
ProTools LE locks up when a region is split bblair 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-01-2009 11:37 AM
OMF2 from Logic to Protools - stereo tracks split MixerGuy Pro Tools TDM Systems (Mac) 3 06-18-2006 03:07 PM
