Old 11-12-2007, 03:51 PM
B Stewart B Stewart is offline
Default Undocumented Fixes in 7.4
Thanks Digi!!!. There are a couple bugs I've had for the last couple of versions (clear back to 7.0) that have been fixed and not in the 7.4 New Features docs (as far as I can tell). These have driven me nuts for quite awhile now. I have two identical rooms and the problems appeared in both as I upgraded each.
First, I use a DoReMi V-1's for video on long form projects. Scrubbing has not stayed in sync since 7.0. Although I've complained for years nothing was done. This is now fixed!!! The V-1 performs flawlously - just like 6.9 and before.
Second, for short form (3 minutes or less) I just use a QuickTime through my Mojo for video. Since, 7.2 (I think), upon audition from the file list using Option-click on the file, the ProTools would eventually lock up. I was told this was a known bug but nothing had been done. If prelaying effects with a Quicktime, I either needed to translate the QT in my Avid to Avid video or prelay using the video in my ProTools computer window. This appears to be fixed as well. Audioting is working without incident.
Now, the only problem I still see is when bouncing to a QuickTime with two video files separated in the timeline by a second or two, instead of putting video black between the spots ProTools puts video white. Very annoying. This popped up in 7.3. How about an update to fix that one?
B Stewart @ The Stewdio, LLC
Pro Tools Ultimate HDX 2022.4 w/HD I/O's and HD Sync
24 Fader D-Command ES
Mac 3.5 GHz 6-Core Intel Xeon E5
32 GB 1866 MHz DDR3 Memory
OS 10.14.6
Soundminer, Izotope RX9, NUGEN Loudness Bundle, Waves Platinum, Restoration, and Surround bundles
Source-Connect, ISDN, Pitch Doctor, Pitch N' Time, etc.
Old 11-12-2007, 05:53 PM
toppo toppo is offline
Default Re: Undocumented Fixes in 7.4
Yeah that's nice.
I am not sure whether it's been documented or not but now Window config can memorize the viewing size and position of movie window which I posted here to request loooong time ago. (It's not a bug though)
Old 11-12-2007, 07:01 PM
Stuart P. Stuart P. is offline
Scrubbing is much more responsive now. Definitely a time-saver for me.
IMDB
Old 11-13-2007, 11:55 AM
subwoof subwoof is offline
Hey Blaine!
Is 7.4 worth the upgrade? 7.3 cs5 seems to be working fine, and I hate to upset the apple cart unless it's worth doing. I figured I'd wait until the first CS upgrade to get 7.4 to give Digi time to fix initial bugs. Is Elastic Audio useful for Post or is it mostly a music thing?
Mike
Michael McDonough, M.P.S.E.
Michael McDonough Sound Design
Old 11-13-2007, 11:59 AM
JFreak's Avatar
JFreak JFreak is offline
7.4 works so much better than 7.3 it is a worthy upgrade whether you use elastic audio or not. just my opinion, though...
Janne
Old 11-13-2007, 12:12 PM
Sonny Keyes Sonny Keyes is offline
I keep a little QuickTime movie of video black just for this. Cut the appropriate length and span the gap. Easy.
Sonny Keyes
Ricochet Audio
Toronto
Sonny Keyes
Toronto
http://www.sonnykeyes.ca
Rig 1: 2.8GHz Macbook Pro PT 12.7.1 Logic 10.3.2 Scarlett 18i20
Rig 2: 2.66 QuadCore Intel Xeon Logic 10.2.0 Scarlett 18i20 PTHD10.3.10
In Search Of: Undocumented Pro Tools 10 Shortcuts Rufio Pro Tools 10 14 01-13-2013 09:09 PM
Undocumented Fixes in 7.4 B Stewart Pro Tools TDM Systems (Mac) 0 11-12-2007 03:50 PM
Undocumented shortcuts tj_davies Tips & Tricks 4 11-01-2007 12:07 PM
undocumented secret? LE on D24? Seeee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-09-2003 08:28 AM
Undocumented keyboard shortcuts Baixo Tips & Tricks 5 10-29-2001 01:46 AM
