Undocumented Fixes in 7.4
Thanks Digi!!!. There are a couple bugs I've had for the last couple of versions (clear back to 7.0) that have been fixed and not in the 7.4 New Features docs (as far as I can tell). These have driven me nuts for quite awhile now. I have two identical rooms and the problems appeared in both as I upgraded each.
First, I use a DoReMi V-1's for video on long form projects. Scrubbing has not stayed in sync since 7.0. Although I've complained for years nothing was done. This is now fixed!!! The V-1 performs flawlously - just like 6.9 and before. Second, for short form (3 minutes or less) I just use a QuickTime through my Mojo for video. Since, 7.2 (I think), upon audition from the file list using Option-click on the file, the ProTools would eventually lock up. I was told this was a known bug but nothing had been done. If prelaying effects with a Quicktime, I either needed to translate the QT in my Avid to Avid video or prelay using the video in my ProTools computer window. This appears to be fixed as well. Audioting is working without incident. Now, the only problem I still see is when bouncing to a QuickTime with two video files separated in the timeline by a second or two, instead of putting video black between the spots ProTools puts video white. Very annoying. This popped up in 7.3. How about an update to fix that one?
B Stewart @ The Stewdio, LLC Pro Tools Ultimate HDX 2022.4 w/HD I/O's and HD Sync 24 Fader D-Command ES Mac 3.5 GHz 6-Core Intel Xeon E5 32 GB 1866 MHz DDR3 Memory OS 10.14.6 Soundminer, Izotope RX9, NUGEN Loudness Bundle, Waves Platinum, Restoration, and Surround bundles Source-Connect, ISDN, Pitch Doctor, Pitch N' Time, etc. |
In Search Of: Undocumented Pro Tools 10 Shortcuts | Rufio | Pro Tools 10 | 14 | 01-13-2013 09:09 PM |
Undocumented Fixes in 7.4 | B Stewart | Pro Tools TDM Systems (Mac) | 5 | 11-13-2007 12:12 PM |
Undocumented shortcuts | tj_davies | Tips & Tricks | 4 | 11-01-2007 12:07 PM |
undocumented secret? LE on D24? | Seeee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 12-09-2003 08:28 AM |
Undocumented keyboard shortcuts | Baixo | Tips & Tricks | 5 | 10-29-2001 01:46 AM |
