MIDI note editing issue
Question on MIDI note editing... I don't see a specific category for MIDI.
Often when I'm editing MIDI notes (moving around, quantizing, deleting) I see that several nearby notes are split into two notes by a change that I made. I then hit Ctrl-Z to undo changes until the split-up notes are re-formed to their original length... as ONE note. Does anyone know what causes this and how to avoid it? I suspect I have some edit setting selected and am unaware of it. I will attach a picture of an edit window with an undesired split note. The long-ish note should be one note instead of one long and two short. |
Re: MIDI note editing issue
PT version?
I'm running Pro Tools 20.5.0.207 on a Mac with Catalina.
I see there is a newer version that I will install. Paul |
Editing MIDI note timing causes major CPU Load | mbahnmil | Windows | 3 | 03-31-2012 04:41 AM |
Editing note in Looped Midi Regions | tele27 | Pro Tools TDM Systems (Mac) | 3 | 05-31-2011 07:03 AM |
8.0.4 MIDI note duration change when editing | Shanti Monkey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 07-27-2010 01:56 AM |
midi note editing | aldoriba | Pro Tools M-Powered (Mac) | 6 | 11-22-2007 12:21 AM |
Probably an easy one..MIDI note editing question | electrocat | MIDI | 4 | 06-10-2005 12:59 PM |
