Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S6
Old 12-25-2017, 06:55 PM
laki laki is offline
Default Sum and Intercancel between MTRX DADman and S6
Hello and Happy Holidays to you all..
Here’s a short vid I made demonstrating a weirdness between the S6 monitoring page and the DADman software on Mac.
ProTools 12.8
OSX 10.12.6
S6 3.7
https://youtu.be/tATtpA7EYRM
Old 12-27-2017, 04:18 PM
creativecontrol's Avatar
Default Re: Sum and Intercancel between MTRX DADman and S6
Greetings,
This is a known issue. If you leave DADman in Sum mode (not Switched) you should be able to successfully toggle between Sum and Intercancel for the Monitor sources from the S6 surface Soft Keys or Monitoring Page.
http://avid.force.com/pkb/articles/e...vid-S6-Support
DADMan: Source selection Sum and Intercancel mode setting conflicts with S6 Monitoring mode setting (GWSW-9640)
The S6 Monitoring local options page lets you configure Source selection for Sum or Intercancel mode, and this setting can conflict with the same settings available in DADMan preferences.
Workaround: Do either of the following:
In the S6 Monitoring local options, set Source selection to Sum mode and then only use DADMan preferences to switch modes.
Configure DADMan preferences to Sum and only use S6 to switch modes.
Jeff
Jeff Komar
Applications Specialist, Pro Audio
MTRX Box JSR Pro Tools | S6 4 11-01-2017 12:46 PM
MTRX antonis Post - Surround - Video 2 10-26-2016 12:31 AM
MTRX 32 Ch. I/O Limitation?? audiobee Pro Tools HDX & HD Native Systems (Mac) 13 10-20-2016 04:13 PM
Avid MTRX Rpro System 5 2 10-12-2016 07:40 AM
Expand Sum/Intercancel suggestion Marsdy Pro Tools | S6 4 02-11-2016 12:06 AM
