#511
Re: -9171 and -9172 errors with Pro Tools HD 10.3 on HDX
suddenly getting - ProTools 9171 errors after upgrading from 10.8.5 to 10.9.5 (HDX) PT HD sept 2016 yes i read this old info: http://avid.force.com/pkb/articles/e...ve-errors-9071 and i'm sure that my work Mac Pro is clean. no junk on it PT HD 10.3.10 mac os 10.9.5 (yes i know not officially approved, but i am told by a very smart person it should be fine) was 10.8.5 just upgraded to 10.9.5 thoughts? thanks |
#512
Trash all the usual, check drive and permission, try again.
Do you also use PT's 12.5.2 or other versions?
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
#513
didnt check permissions tho.... where? how? and i only use PT HD 10.3.10 thanks. |
#514
Computer specs and what model hard drives do you have? Ram etc
#515
I just experienced this problem today: Bouncing a single track (wav file) to MP3.
NO PLUG-INS running. (PT 11.3/OSX 10.8.5 Mountain Lion/iMac/2.9 GHz Core i5) Never had this problem until today. Kiki |
#516
Same boat. New system 12.6.1 9171 errors. A few avid plugs. $5000 card that doesn't work. 3 weeks of this crap. If a don't find a solution by the weeks ends, I'm returning the card and leaving this platform. Anyone else on board?
Tim |
#517
#518
I'm bringing this thread back to share my recent experience with this issue and to hopefully to shed some light on a (sort of) fix that works for me ...
My current system: Mac Pro 5,1 12 core 64GB ram OSX 10.12.1 Pro Tools 12.7.0 HD Native PCIe w/ Avid Omni I've been using this same HD Native PCIe / Avid Omni combination for several years across 3 different Mac Pro's and from PT version 9 up through my current 12.7 set up. I have always had -9171 and -9172 "Audio processing could not complete due to conflicts with other CPU tasks or a potential clocking issue..." errors to some degree or another on all my HD Native systems. The CPU usage would never be more than 50%, sometimes as low as 20% with a low track and plug-in count and no matter what the errors would pop up from time to time. Over the last two weeks I've switched my playback engine to the Mac Pro's built in Digital output and voilΰ! no more errors. Not one. I've been running 60+ track sessions with HEAVY plugin usage and a playback buffer of 64 with zero errors. The CPU usage generally sits around 25% unless I go nuts with plugins. The min I switch back to HD Native the same session will double in CPU usage and the errors start up unless I raise the playback buffer significantly. I suppose my particular card my just be bad, but given the amount of posts on this issue I'm pretty convinced the errors are due to poor communication or a bad driver between PT and the HD Native card in general. I highly recommend you give your computers internal audio output a try and see if the errors stop. It's not a real solution but might it be a workaround for some. |
#519
Bad Driver.
Needs multi-client layers to play with all (or compliance). Firmware + Software. (My Best guess today)
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit Last edited by DetroitT; 05-01-2017 at 05:13 AM. |
#520
had the same native card + omni...the 16x16
same crap errors with barely anything going... audio stopping so I finally sold that stuff really UNgood plus you need HD only to access that HW? 400 a year to have MORE errors than vanilla native wow what are they thinking
Hal Cragin On the DUC Since The Year 2000 AD Ventura ,PT 2022.10, MacbookPro 13"[2020] M1 16G, Antelope Orion 32+ Gen3..SSL Sigma summing, SMART Comp C1LA, CharterOak EQP-1 Oceanway Audio HR4S monitors . SSL X-Rack w XR618 compressors, dbx 160x [2] |
Pro Tools 10.3 9171 and 9172 Errors | Tops3b | Pro Tools HDX & HD Native Systems (Mac) | 20 | 07-14-2013 03:11 PM |
-9171 and -9172 errors constant...Sandra attached | wrachilla | Windows | 12 | 05-09-2013 09:19 AM |
UAD triggering 9171, 9172 errors? | xq3js | macOS | 7 | 03-22-2013 11:47 PM |
Dae errors -9171 after installing 10.3.3 | TCM | Pro Tools HDX & HD Native Systems (Win) | 3 | 02-06-2013 10:18 AM |
10.3.3 Major Fail....9171, 9172 and 9129 Errors | Tops3b | Pro Tools HDX & HD Native Systems (Mac) | 3 | 12-21-2012 07:21 PM |
