Closed Thread
Old 03-24-2011, 11:09 AM
_mat _mat is offline
Smile RESOLVED: I updated PT LE 8.0.1 to 8.0.5 AFTER the Eleven Firmware-Flash...
Hi there!
I updated PT LE 8.0.1 to 8.0.5 LAST - I did the ELEVEN Firmware-flash to 2.0 before...
Just noticed now in the forum-Sticky, that I was doing this the wrong way.
Is there any solution, to 'see' the new apps in PT and bring it to work correctly?
I tried to flash back the Firmware to 1.3 but it didn't worked, it's not beginning the install. So for now, I just can use Eleven in Standalone or 'half the way' in PT (new amps, fx etc. are not listed etc.).
Many thanks in advance!
Mat
P.S ...I'm on a Mac with Snow Leopard 10.6.7
Old 03-24-2011, 11:10 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: I updated PT LE 8.0.1 to 8.0.5 AFTER the Eleven Firmware-Flash...
just run the ERXP again. you dont need to update the Firmware again.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 03-24-2011, 11:53 AM
Thanks for your quick answer!
I tried this before - without success.
Right now I downloaded the ERXP again and run it - and it worked
Thanks for this cool Update!
Mat
Closed Thread
HD Native Firmware Flash TimNielsen macOS 5 01-29-2012 01:59 PM
MIDI I/O Firmware flash? DetroitT MIDI 0 09-26-2011 08:52 AM
RESOLVED: Eleven Rack Expansion Pack Firmware-HELP!!!! martinaston Eleven Rack 3 04-03-2011 08:18 AM
Updated to X2 , Now resolved BIG D Pro Tools TDM Systems (Win) 8 05-24-2006 01:34 AM
SSD..updated firmware, now light just flash, doesn't work!! HELP!! maxtraxstu Pro Tools TDM Systems (Mac) 6 01-18-2000 03:52 PM
