Anyone using Vienna Ensemble Pro?
Just purchased and installed it, but I'm having a hell of a time getting ProTools to work with it. Read through the VE Pro manuals and videos, but doesn't seem to explain some of the basic routing issues that I think are the root of my problem. If anyone could shed some light, I'd love to post some more details of what's going on and maybe figure this out.
@wildhoneymusic http://kidzbop.com/music/ https://concord.com/publishing-roster/gary-philips/ |
Re: Anyone using Vienna Ensemble Pro?
4-6 threads here with this exact title but I don't think anyone had the issue(s) u may be speaking of...
So whatz goin on? here are some of the others <> <> <> <> <>
First issue: I create an instance of Omnisphere in VE Pro. Channel 1 of Omnisphere. I create a MIDI track in PT and set the output to "VE Pro 1 1." Works brilliantly, audio gets spit back into PT via the Instrument Track I've got the VE Pro plug-in on. Load another Patch in channel 2 of Omnisphere, create another MIDI track in PT and set output to "VE Pro 1 2". Again, works great, audio coming through the Instrument Track in PT. Now I create a new instrument in VE Pro and load MotU Mach5. I create a new midi track in PT and set the output to "VE Pro 2 1." But when I play through the latest midi track (aimed toward Mach5 channel 1) I get not only the Mach5 channel 1 sound, but also the Omnisphere channel 1 sound. So it seems the midi routing I have going is not discrete. Second issue, unrelated: From within Omnisphere, I want to send the output of channel 1 to output B and the output from channel 2 to output C. Typically, in ProTools, I'd just adjust the output routing in Omnisphere, then create audio or aux tracks and set their inputs to Omnisphere out B and C respectively. Now, in VE Pro, if I change the outputs in Omnisphere, I can't seem to find an input in ProTools that will let me hear the output of Omnisphere B and C. In PT, I see outputs coming from VE Pro labeled Stereo 2 through Stereo 16, but within VE Pro, my output options seem only to be Master Bus or a series of Net3/Net4, Net5/Net6, etc outputs. And further, those outputs will only assign the output of the entire VI, not the individual midi parts within the VI. Sorry if this is long-winded. Trying to be thorough, but brief. Hoping if somebody can hip me to the proper workflow with this stuff I can figure out all the minutiae on my own.
I can answer the output issue without being in front of it...the 1st issue, I need to be sitting @ it because I too had to figure that 1 out my 1st go around...If no one else chimes in before I get too it, as Arnold says, "Owl Be Bock"
As for the output thing, In VEPro, there are Inputs that u can(must) create, then setting the hardware output of that input track in VEP accordingly so that u get it into PT where u want it.(I think I said that rite).. I always do aux tracks in PT & set those...
First off I don't know if you are on one machine or if you are in a Slave and Master machine situation. Are you using the Server plug or the Stand Alone version? In any case this may help.
For your first problem, make sure that your Mach 5 is receiving on it's own port and that port must be set to omni if you want that instrument to receive on all 8 channels. This could have something to do with the way you have midi setup. I find that midi works perfectly by using the VEPro system and disabling any other midi systems you may have.......could be iPmidi or MOL. You disable other systems by NOT selecting them in your server setup. I'll try to explain what I do in your second scenario. To get your separate outputs from Omnisphere in VEPRo you first create your Omnisphere instrument. THEN you create another INPUT channel in VEPro (that's the icon 3rd from the left at the bottom of the screen.) At the bottom of that channel there are two boxes. The first one allows you to choose Omnisphere 2 the second one is your output to ProTools. So select which NET out you want. So in VEPro the outputs work like this Net 3+4 = ProTools stereo 2 Net 5+6 = ProTools Stereo 3 (so always the VEPro out is double the number of the PT in) That will now work. So the creation of the Input channels in VEPro for Omnisphere is where you went wrong. Good luck with VEPro. It changed everything.
HD Accel 2, Magma PER64-I Mac Pro 2x3.2 Quad Core/OSX 10.6.8/VEPro/PT9.03 http://philbuckle.com/ |
Thanks for the clear explanation of how to use Input channels in VE Pro to get discrete outputs from the VI's. Not as elegant as I imagined it would be (just assumed you'd be able to access a VI's outputs more directly from PT), but at least now I totally understand how to set it up. I'm not even going to ask why the names of the out's and in's don't match up. . . .
Thanks for chiming in Phil... I don't really get in the studio on tues as that is my "Forum Day"
Glad to be of assistance. The thing is that once you have set up your template with your main plugs all split out etc you never have to do it again.
The problem is that there are now too many toys available to me. I'm going to have to cut up my credit cards to stop me buying stuff that I always wanted to use in PT. Just bought another Scarbee piano for Kontakt 4. Can't help myself!
I kno rite!!! All cash for me, so I don't kno which is worse
U with the Credit Cards or me spending cash(that I owe the IRS)
Vienna Ensemble Pro | Belegur | Virtual Instruments | 23 | 03-31-2015 01:07 PM |
with PT 11... no more Vienna Ensemble Pro? | Anibal | Pro Tools 11 | 14 | 11-06-2013 11:04 AM |
Vienna Ensemble PRO 5 | filosofem | Pro Tools 10 | 103 | 07-31-2012 07:11 AM |
Vienna Ensemble Pro | d.f. | Pro Tools TDM Systems (Mac) | 154 | 06-11-2012 11:04 AM |
Vienna Ensemble Pro | d.f. | Virtual Instruments | 0 | 03-09-2010 08:22 AM |
