Old 01-05-2009, 07:03 AM
WildHoney WildHoney is offline
Default Carbon Copy Cloner question
At the risk of embarrassment, sometimes I'm shocked by the basic computer stuff I DON'T understand, so I'm hoping somebody can enlighten me.
When using Carbon Copy Cloner, what's the advantages/disadvantages of having it back up my system drive as a "new disk image" as a opposed to the standard way CCC backs up (with the various files just duplicated to an external drive). Thanks for any help.
Old 01-05-2009, 07:41 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Carbon Copy Cloner question
A disk image can be store/moved/copied easily onto another disk or DVD etc! so you keep keep different disk images from different times and reference back to them etc, so you could keep 20 disk images all slightly different and re-install them if needed.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-05-2009, 08:21 AM
Originally Posted by crizdee View Post
Chris
If you make a disk image, can you still dip into it for specific files/folders? e.g. in the past, I've been able to screw up a Waves update (for example) and then dip back into my CCC backup drive and just grab the Waves files/folders from my backup system, copy to my main system and be back up and running. Thanks for the help
Old 01-05-2009, 08:49 AM
kptkarl kptkarl is offline
Yes you can mount the disk image by double clicking it.
Carbon Copy Cloner (or sim) copy Disk Authorisations? Jon_Atkinson Pro Tools TDM Systems (Mac) 8 10-07-2009 08:11 PM
Question about Carbon Copy Cloner Shanegrla 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 08-27-2009 09:50 AM
Is Carbon Copy Cloner the answer? jlcnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-15-2004 10:55 AM
New boot drive in OSX with Carbon Copy Cloner? Chris Pro Tools TDM Systems (Mac) 3 11-15-2004 10:17 PM
Carbon Copy Cloner joepopp Pro Tools TDM Systems (Mac) 17 12-08-2003 11:25 AM
