Old 10-12-2011, 03:14 PM
Rebel Rebel is offline
Smile PT 9.0.5 with Lion - unable to open other MIDI apps open as standalone
PT 9.0.5 with Lion and having these SW open as STANDALONE:
(Garage Band, Audio MIDI Setup AMS, Sibelius, Logic)
NONE of these applications will open unless I connect to my DIGI 002R AND a Pro Tools session is open.
Otherwise it gets stuck when trying to open those apps. I do not think thats' the way it's supposed to be.
Somewhere there might some sort of preference which overides ProTools' priority on this matter.
Each Application' individual message:
1 - AMS : "Audio MIDI setup couldn't open the MIDI server so you can't view or edit your MIDI configurations. If you recently installed a new MIDI driver, try uninstalling it and then open Audio MIDI setup again. If Audio MIDI setup works correctly after that, contact the driver's manufacture for further support"
2 - Logic : stuck on "checking MIDI drivers" ; "MAC OS X MIDI Services not available" is displayed when the Logic finally opens it.
3 - Main Stage 2 : stuck on "initializing MIDI" . "Unable to launch the MIDI Service"
4 - Sibelius 6 : "Error initialising OS X MIDI system"
5 - Garage Band : It actually opens !!!
"core audio", "aggregate", "audio devices", "MIDI Server" and "audio engine" are related to this issue. Will look for those on existing documentation that came with the SW
Any help is appreciated, though
MacBook Pro, DIGI 002R
Old 10-12-2011, 03:27 PM
DigiTechSupt's Avatar
Default Re: PT 9.0.5 with Lion - unable to open other MIDI apps open as standalone
Look in the General Troubleshooting thread and trash the specific Core Audio and MIDI preference files indicated in that thread, then restart and test again.
Avid Audio Tech Support
Support FAQ
Old 10-12-2011, 04:02 PM
Hi, thanks for your reply!!
I believe you're refering to the link General Troubleshooting - Pro Tools LE Mac , since that's the closest match to my system.
As suggested there, I should delete these files and restart the system:
* com.digidesign.CoreAudioManager.plis
* com.apple.audio.AudioMIDISetup.plis
* com.apple.midi.a bunch of numbers and letters.plist'
* com.apple.audio.audiomidisetup.plist
However:
a) I cannot locate the 2 pathes suggested ("Mac HD > Users > (Your User Name) > Library > Preferences" and "MacHD>Users>your account>Library>Preferences>By Host")
b) I do find some "com.digidesign" and "com.apple" files at "Mac HD > Library > Preferences" but, still, cannot find ANY of the files suggested to be trashed.
Thanks!!!
Mac OS X Lion 10.7.1
Old 10-12-2011, 04:27 PM
I'm afraid that doesn't apply to PT 9.0.5 with Lion ...
Please remember I have already dowloaded and installed a month ago the following drivers as recommended by Avid
(MIDI has been working fine on Pro Tools sessions by the way)
a) DigiDioMidiDriver.plugin Fix v9.0 for 003 and 002 Family
b) MIDI I/O driver for Mac (v90_69602)
c) 002 and 003 family Drivers v9.0
Old 10-12-2011, 06:22 PM
Yes, it does apply. You have to enable viewing of the Users>Library folder. The Pro Tools 9.0.5 Read Me has information on how to do this in Lion.
Support FAQ
Old 10-15-2011, 12:38 AM
Hezul Hezul is offline
I'm having the same problem. If you delete "DigiDioMidiDriver.plugin" from HD>Library>Audio>MIDI Drivers everything works fine, except that you lose your interfaces MIDI I/O. (The library folder is hidden, so you have to go to Finder alt+click the "go" menu, and choose the library folder from there.)
I'm really irritated by this since I use both Sibelius and Pro Tools throughout the day and I need my Digi002's MIDI ports operational because I control my guitar rig with Pro Tools. The "DigiDioMidiDriver.plugin Fix v9.0 (Mac) for 003 and 002 Family [0.23 MB]" doesn't solve anything. It just writes the same "DigiDioMidiDriver.plugin"-file back to where it was and messes up the MIDI-functionality.
Anybody know about a solution?
Old 10-15-2011, 03:25 AM
phydaux2000 phydaux2000 is offline
I also have this problem.
Old 10-15-2011, 02:40 PM
Have you tried deleting the preference files I referred to in my previous post?
Support FAQ
Old 10-15-2011, 07:41 PM
Yes, to no avail.
Old 10-16-2011, 12:04 AM
Vincent Joly Vincent Joly is offline
Sorry for my poor english
I have also the same problem. When I was on PT 8.0.5 there is no issue.
Impossible to run GarageBand and all SW like arturia standalone and other
Since I am on PT 9.0.5 I have always the same problem but I found a solution
1) I run audio and midi setup
2) I select Digidesign HW (003) and I config HP when I click on left HP or right HP, Digi CoreAudio Manager comes on Dock
After that all runs fine, I can close audio and midi setup
I think there is a problem because "Digi CoreAudio" makes crash Lion's midi server.
Vincent
My config :
Imac 27" I7 3,4Ghz, 16Go, OS 10.7.2
PT 9.0.5, 003R+
Unable to open Sessions (Tracks unable to load) palmify91 Pro Tools 10 1 03-27-2013 08:00 AM
PT9.0.6 Won't Open in Lion 10.7.2...?? tomhartman macOS 2 01-08-2012 11:27 AM
Avid midi driver with lion make all other apps using midi hang!!! TREXROCK macOS 4 10-30-2011 05:39 PM
Unable to open Midi Studio Setup yvan Pro Tools TDM Systems (Mac) 8 08-25-2005 03:55 PM
Digi CoreAudio vs. other open apps jes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-30-2003 10:09 AM
