Old 10-07-2014, 10:52 PM
simonyeah simonyeah is offline
Default Eucon and hui controllers all together
Hi
Anybody knows if a "old" hui type control surface like a control 24 or procontrol can run in parallel with a eucon type controller (like artist series) in protools hd10 (not 11 I know).
My aim is to run an old control 24 with an avid transport to add eucon shortcuts such as preview, write to selection...
Thanks in advance
Best
Simon
Old 10-08-2014, 12:48 AM
Audioartist Audioartist is offline
Default Re: Eucon and hui controllers all together
Are control24 and procontrol really HUI?
I use Yamahaconsoles in HUI mode together with eucon, works good except for some of the eucon bugs.
D-control ES 32 - Venue Profile 48x24 - S3L-X - Yamaha DM2000 - Artist mix and control - HD7 accel - HDX2 / Magma EB3T
HD native thunderbolt
PT10HD 10.3.8. - PT11HD 11.3.2
2xHD madi - 2xHD omni -
Old 10-08-2014, 01:02 AM
Actually no, you are right. I made a mistake. My question concerns digi older Ethernet controller and eucon. Anyone has managed to make them work together ?
Old 10-08-2014, 01:07 AM
I dont think that it will work. When you click the ethernet checkbox to connect an Icon surface it says that it does not work together with eucon if you have eucon checked, I guess its the same with other ethernet surfaces.
Old 10-08-2014, 02:10 AM
thank you for your reply.
That is really too bad...
Old 10-08-2014, 04:28 AM
8dB.co.uk 8dB.co.uk is offline
I use an Artist Control together with V-Control (hui), but you lose the metering on the hui. I'm guessing that's because hui only supports stereo channel meters whereas Eucon supports multichannel. The same applies to diginet so I'm guessing that's why it won't play nice with Eucon, as well as other things.
Pro Tools Utimate 2018.7, on -
i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB;
Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB;
"Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB.
RME FireFace802 + ARC, RME Babyface
Avid D-Command, Artist Control, V-Control, Korg MicroKontrol
7.1.2 Presonus Monitors
Pro Tools 10 HD freezes at "Restoring Controllers....Configuring EUCON" Mr. Light Artist Series 1 02-25-2016 10:42 AM
Eucon conflict with other controllers in Pro Tools jacko Artist Series 3 04-22-2015 09:09 PM
d-Command and MC Transport / You cannot use EUCON with other Ethernet controllers wouters Artist Series 2 04-17-2014 01:28 PM
Setting up eucon and artist controllers trock macOS 2 01-06-2013 05:46 PM
Artist Controllers and EuCon with Mountain Lion 10.8? Krzysztof Artist Series 43 12-03-2012 01:21 PM
