Old 06-12-2019, 02:01 PM
milescoolin71 milescoolin71 is offline
Default OSX 10.14 Mojave
Is anyone running PT 12.4 with Mojave? What are your experiences? I would like to upgrade my OS but obviously don't want any surprises. I am already aware that Pro Tools 12.4 is not "officially" supported beyond OSX 10.11.6. I am just curious what people experiences are with Mojave. Thanks in advance.
Old 06-13-2019, 04:21 AM
Default Re: OSX 10.14 Mojave
Do you have any real need to change your installed OSX to a newer version other than the fact you're running the worst OSX Apple ever put out? Remember that Mojave needs a Metal compatible video card - does your Mac have one? Without that the max you can go to is High Sierra.
Either way you go keep in mind you'll want to do a clean install of EVERYTHING and not use Migration Assassin (aka Migration Assistant) to bring things over. Or do the OSX dance the Apple Way aka an in-situ upgrade where you install the new OSX right over the top of the old. That's a no-no as well as too many weird things can crop up.
Jack
QAPLA!
Old 07-03-2019, 01:19 AM
EdwardG's Avatar
EdwardG EdwardG is offline
pro tools 12.7.1 in mojave 10.14.5 here.
installation went just normal in mac os new installation.
import audio not working instead use drag and drop.
Preset section in protools works but in a different manner, you cant use the plus and minus buttons to circle trough presets it jumps through them for not reason.
that's everything I experienced. with your version you may experience different things or maybe non.
Old 06-05-2022, 03:33 PM
SidBarone SidBarone is offline
Did you previously have PT 11 running in Mojave 10.14.5 ?
Protools 11
MOTU Interface
iMac 27" 2011, 3.4 GHz, 16GB, OSX 10.13
Old 06-06-2022, 09:19 AM
EdwardG's Avatar
Its being like 3 years or more since then... cant remember, but I always do clean installs by default,
I remember that back then I found the reason to that problem and it was because of incompatibility
between pro tools and APFS new format.
If it helps to anybody
Reverting back to MAC OS extended Journaled fix the issue.
Mojave 10.14.5 massivekerry macOS 48 04-10-2020 01:02 PM
Mojave or not Brian Hudson macOS 2 05-23-2019 09:35 AM
Mojave? hanksinclair Artist Series 3 05-03-2019 03:19 PM
Mojave ? Riquier macOS 89 02-26-2019 06:41 PM
Mojave Audio mic - anyone tried one? JSM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-08-2003 02:49 PM
