PT 12 Crashes w/ Motu BPM
Hello
I have used Motu's BPM as a plug-in on PT for almost a decade - but both were running on a pretty old system. I recently updated everything. Currently running PT 12.4 on a Macbook Pro OS X 10.11.6. Works lovely. I just re-installed BPM. It works as standalone software, but when I go to select it as a plug-in, PT immediately crashes. Motu says this is Avid's fault. Avid says this is Motu's fault. I would love to get BPM back up and running as a plug-in. Anyone have any recommendations on troubleshooting this issue? Thanks! Best Ian |
Re: PT 12 Crashes w/ Motu BPM
Hi Ian,
I have the same problem and have had for a long time! BPM has been pretty much broken ever since MOTU released the AAX version. I actually don't think it has ever worked in any version of Pro Tools, just causing PT to instantly crash after inserting it to a track. Also, it's been ages since MOTU last updated the plugin and who knows if they ever will again... My solution, and probably also your best bet, is to use the Blue Cat's PatchWork Synth plugin on an instrument track to host the VST version of BPM instead of AAX. The VST version works perfectly this way, so there is definitely something wrong with the AAX version of BPM. A shame really, because BPM is really one of the finest VI plugins out there! If you have a little spare money i suggest you invest in the Blue Cat's PatchWork plugin for this little workaround! Best regards, Swedish |
You could also try BPM standalone and run MIDI to it over the IAC Bus, and connect the audio with Soundflower...
Just a thought if you wanted a free solution
Mac Pro 2019 3.5GHz 8 Core 48GB RAM OS 13.6.3 Protools Studio 2023.12 Antelope Orion 32, Vienna Ensemble Pro 5, UAD Quad PCIe |
UVI Workstation keeps updated.
BPM is at version 1.5.3 Please indicate your system version.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
I can confirm that BPM (AAX 1.5.3) is a complete non-starter in PT...
Works fine in any other format, but forget AAX, (or Motu/UVI ever addressing the issue). I've been trying for nearly 2 years to get Motu to resolve this, & yet they still continue to market BPM as being "AAX compatible". Motu blame UVI... UVI blame Motu... I've owned a lot of Motu hardware over the years, but I won't deal with them (ever) again...
www.fluidity-studios.net Last edited by ::F-L-E-X::; 03-10-2017 at 07:26 AM. Reason: typo |
You can get bpm to work if you load it in a protools 10 or 11 session save it then open it in a protools 12 session. It works but still won't load up in 12. Worth a try I am using it now in 12.18 aax.
Pro Tools 12 crashes and crashes... | Phantobias | Pro Tools 12 | 12 | 09-15-2015 11:08 AM |
PT Crashes and crashes again... Help needed! | heabow | macOS | 5 | 01-23-2015 02:44 AM |
PT 10 Crashes with MOTU 424 PCIe MAC | lexaudio | macOS | 6 | 03-31-2013 01:46 PM |
DIGI 001 and Motu 2048 MK II or Motu 24i+ Logic Audio | cyril | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-19-2002 09:08 PM |
Good Midi Interface For 001 using a G4? Motu Fastlane Crashes My Computer | SHC | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-05-2001 03:44 AM |
