Old 01-21-2011, 10:35 AM
nuancerec nuancerec is offline
Default HD Native Delay Compensation not working!
I've tested my new HD Native system (paired with the HD 16x16 I/O) and it is not compensating for delays in the following plugins. It is set for "long" delay compensation and is enabled
- AutoTune EVO - dly 1380
says it's compensating but i can hear obvious phasing
- Autotune + Time - dly 2660
same issue
- Antares Harmony engine - dly 1280
same issue
- Time adjuster long - any delay values
- DrMs - not true bypass in bypass mode - can hear large delay
- Ozone 4 - but that's always been a problem
Yet it works for all my Waves plug-ins
any help?
- M
Old 01-21-2011, 12:08 PM
maxon maxon is offline
Default Re: HD Native Delay Compensation not working!
best way use TDM plugins
RECORDING Studio: Mac Pro, OSX 10.6.8, PT HD 3 PCIe, Pro Tools 8.1.1,
MIX + MASTERING Room: MAC Pro, OSX 10.6.8, PT HD 3 PCIe, PT 8.1
3x 192 I/O, Digidesign PRE, UAD Octo, UAD Satellite Ultimate
Old 01-21-2011, 12:11 PM
Dism Dism is offline
How do you propose to do that on an HD Native system?
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 01-21-2011, 12:45 PM
danander11 danander11 is offline
By squinting when enabling them...
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
Old 01-21-2011, 01:12 PM
KMcK KMcK is offline
Just guessing, but my bet would be that the Antares plugs aren't coded to report their delay properly since you're seeing it with multiple plugs from them - and if that's the case, the onus falls in Antares lap to code their software better, not Avid's.
Old 01-21-2011, 01:13 PM
Also - getting the same issue with Slate Digital LGX and Speakerphone
Old 01-21-2011, 07:33 PM
Well... curiosity got the best of me.. I loaded a basic template of mine this morning and tried the plugs that I have that match your list.. Antares harmony, ozone 4, time adjuster long... and no problems whatsoever. ADC works as it should.
The qualifier here is that I'm using 9 with the cptk and not HD so the issue, it seems to me, may lie in that code.. although I though they were the same, just un-instatiated features..
Don't know if this helps to clarify or muddy things.. DTS?
Here I am,
Hobo Shave!
Old 01-22-2011, 11:45 AM
DigiTechSupt's Avatar
Can you post a session for me to look at? Are you on Pro Tools 8 or 9?
Avid Audio Tech Support
Support FAQ
Old 01-23-2011, 12:16 PM
mrjohn mrjohn is offline
same issue
same issue
- M
In my experience the phasing effect on Autotune is normal - even when bypassed it still affects the sound in a random way.
As for the time adjuster, surely if its delay was compensated then it would cease to function?
John
Mac Pro 2 x 2.8GHz Quad
OSX 10.10.5, PTHD 12.4.0
Old 01-23-2011, 05:29 PM
Using PT HD 9 for Mac - I even measured the discrepancy in the delay manually. The plug-in is under-reporting the delay by about 30 samples. I guess I can just manually enter this, but it kinda defeats the whole purpose of ADC.
- M
What the hell is it now.. Delay Compensation not working on Midi? makinghits Windows 13 01-07-2014 06:03 PM
Delay Compensation Randomly Stops Working edit machine Pro Tools TDM Systems (Mac) 6 11-02-2010 06:45 AM
Automatic Delay Compensation not working like it should Edgur Pro Tools TDM Systems (Mac) 8 08-19-2009 07:25 AM
Delay Compensation Has Stopped Working voce Pro Tools TDM Systems (Mac) 5 07-08-2009 12:32 PM
Delay compensation not working for RTAS plugs dkesler Pro Tools TDM Systems (Win) 5 11-20-2007 08:41 AM
