Old 07-23-2008, 12:20 PM
Steve White Steve White is offline
Default EQ3 4 band
I have version 7.4 TDM HD on a Mac G5. We have recently just upgraded to a C|24 controller and installed 7.4. When I try to put a EQ 3 4 band plug in on a track Pro Tools says it is not compatible with this version. It will allow me to use RTAS. Why is this? The compatibility chart for this plug in shows that it is a TDM plug in.
Steve White
South Carolina Editor
Old 07-23-2008, 03:08 PM
crizdee's Avatar
crizdee crizdee is offline
Default
Try manually removing the current version from the plugins folder and then re-install the latest version from the downloads.
Otherwise you could try trashing the prefs as described in the troubleshooting thread in the stickies. also in the stickies is an application for saving and trashing all the prefs!!
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
.band to PT frcjt macOS 3 05-19-2013 07:48 AM
what mic´s to get to mic a whole band hlynur Pro Tools TDM Systems (Mac) 6 12-10-2006 07:42 AM
OT - YOUR best band name(s) graveleye 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 39 01-20-2003 12:18 AM
Bussing of 1-band or 4-band EQ TonyR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-15-2002 01:02 PM
One band EQ? sonoma bass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-05-2002 09:08 AM
