Old 03-31-2016, 03:04 PM
john1192 john1192 is offline
Default Re: Command 8 - Compatible
thx for the update .. hope you can get it repaired ..
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 07-01-2019, 04:17 AM
hornedrum hornedrum is offline
How did you all get Command 8 working?
I just upgraded from PT 10 to 12.5.2, on Sierra OS and can't get the Command8 to be seen at all.
Do I need EUcontrol software installed, and if so, should that be an earlier version like 3.7 which worked on Mavericks, or there latest version on the AVID site?
Thanks
Old 07-01-2019, 05:30 PM
Top Jimmy's Avatar
Default Command 8 - Compatible
Thanks
No on the Eucontrol.
You need to set up the Command8.
Setup menu > Peripherals > MIDI controllers.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Sierra 10.12.6.
Pro Tools HD 2018.12, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
D-Command Firmware update backwards compatible? inky macOS 4 09-18-2014 01:48 PM
Command Keyboard Focus mode ' E ' command bug ? vudoo Pro Tools TDM Systems (Win) 2 09-10-2009 05:49 AM
Leopard / PT 7.4-PR / Command|8 not compatible? eric22rr ProControl, Control|24, Command|8 2 06-10-2008 11:38 AM
Total Loss of Command 8 Command/Modifiers John Pisciotta ProControl, Control|24, Command|8 1 05-13-2005 10:30 AM
Command 8 ANd 001 compatible? eddierojas ICON & C|24 0 04-05-2004 07:47 PM
