Old 03-10-2018, 07:50 AM
Raoul23 Raoul23 is offline
Default OSX 10.9.5 no waves in audiosuite??
Just noticed my waves plugins are not in the audio suite drop down menu??
Waves version installed os 9.3 anyone no how to fix this issue do i have to rescan a folder or something. Ive tried a fresh install but this didnt sort the issue.
Thansk Raoul
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 03-11-2018, 11:30 AM
This is strange as I’ve just checked my Mac Book Pro which is running 10.9.5 and waves are in the audio suite drop down menu?? I used same installer and everything??
I’m confused ??
Raoul Crane
Old 03-12-2018, 02:10 PM
Default Re: OSX 10.9.5 no waves in audiosuite??
Sorted, some how I must have hit don’t use audio suite plugins when pro tools first scanned the folder. Waves support pointed me in the right direction
Raoul Crane
Old 03-13-2018, 11:17 AM
Well I thought it was sorted, booted Mac up today and the waves plugins were missing from the audio suite again. I closed PT held shift and reopened PT and guess what?? The box next to don’t use audio suite was ticked again. Now I no for a fact I didn’t tick it this time. I’ve sent waves support an email hopefully these can help me
Raoul Crane
Old 03-13-2018, 11:22 AM
crizdee's Avatar
crizdee crizdee is offline
That is something you usually do when installing? tried running the installer again?
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-13-2018, 11:28 AM
Hi Chris
Run the installer 2 times now, still the same ??
Raoul Crane
Old 03-13-2018, 01:22 PM
crizdee's Avatar
Could try trash prefs
User/Library/Prefs/Waves/pluginFolder_scanView
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-13-2018, 01:39 PM
Thanks Chris I’ll try that
Raoul Crane
Old 03-16-2018, 11:29 AM
That worked Chris, thank you
Raoul Crane
Using Waves Tune in Audiosuite Mark Swanson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-28-2011 10:26 PM
waves overwrite in audiosuite utility 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-03-2009 10:24 AM
Waves V6 can't use "Audiosuite" modulo2008 Pro Tools TDM Systems (Mac) 2 07-09-2008 09:29 AM
Waves AUDIOSUITE latency Darin Donovan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-31-2003 09:11 PM
Waves 3.0 / Audiosuite question daiker Pro Tools TDM Systems (Mac) 11 01-17-2001 12:41 AM
