Old 02-14-2018, 09:09 AM
Sam C's Avatar
Sam C Sam C is offline
Default Eleven Rack midi question
I have a Mac on High Sierra, PT 12 with a UA Apollo 8 interface. My Eleven Rack runs through the Apollo via sdpf. If I hook my midi keyboard to the Eleven rack can I generate midi from my Alesis to the Apollo to Pro Tools 12 2018?
I just got the Apollo and of course there is no midi connection. I only use midi for virtual instruments and I am trying not to use a USB Midi connection cause I am out of USB slots and don't want a USB Hub.
Thanks
Sam
Sam
Old 02-15-2018, 02:46 PM
Sam C's Avatar
Default Re: Eleven Rack midi question
There must be a guru here that could help, please.
Thanks
Sam
Old 02-15-2018, 09:54 PM
Is the Eleven Rack connected via USB for editing? If it is, check Setup>Midi>Midi Studio to see if the midi ports are available
Old 02-17-2018, 11:30 AM
Sam C's Avatar
Thanks Albee ...yes in midi studio set up the eleven rack is there and connected virtually.
Alesis out to midi in/midi in to midi out on 11 rack. Alesis shows it’s sending a signal and my instrument track shows Alesis channel 1 Omnisphere Channel 1....but no sound. Since the 11rack is connected via usb shouldn’t this be all that I need to do?
I’m confused why I cannot generate a midi signal.
Thanks for any help!
Sam
Old 03-11-2018, 09:25 PM
Mikeit Mikeit is offline
I'm not too sure about pt, but logic can only use one interface at a time, as far as I know.
Have you tried using the eleven rack as the main interface? Even though your connected through USB, in your preferences in PT your main interface for audio is the Apollo, just for fun change it to the 11r, and see if you get signal from the Alesis, just a thought....
Disabling MIDI patch changes, when recording MIDI through the Eleven Rack? amnesian48 Eleven Rack 2 04-07-2014 01:58 PM
Question eleven rack and Th2 djkal Eleven Rack 8 08-04-2013 11:22 AM
Eleven Rack Question jerry g Eleven Rack 7 07-24-2013 12:28 PM
I/O question Motif Rack ES & Eleven Rack greenetunes MIDI 4 05-27-2012 07:47 PM
Eleven Rack & 003 Rack+ question deadshot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 04-29-2011 12:14 PM
