Old 01-29-2018, 06:39 AM
munchman munchman is offline
Default Instability Issue
Hi all,
I have a an issue, which I did scan the forum for but couldn't easily find the exact issue. One guy got told off for something similar, so go easy of this is a stupid Q please as I did have a look.
I use my 11R as my main interface (hoped to at any rate). Its connected to the MBPro via USB, with XLR outs to monitors. I use Studio One Pro for a DAW, also Logic.
Problem: The interface crashes periodically in the DAW, resulting in no sound. If I pull out the USB and put back in, its ok for differing lengths of time, then the same again.
I would be grateful for any help please as I really didn't want to revert to a separate interface if possible, its just so convenient with the 11R.
many thanks
Helpful info:
MBPro 2015
16g Ram
SSD HD set to no sleep
OS - High Sierra
Old 01-29-2018, 09:18 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Instability Issue
So no sleep setting... do you have the current driver?
What about USB port? Is it connected directly to the computer or a hub? Have you tried a different port maybe? Maybe a different cable?
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 01-29-2018, 10:17 AM
Hi, thanks for getting back. I tried both ways as it was in the hub originally, no luck. Im on the latest driver as far as I know, unless theres been something recent?
Thanks again
Old 01-29-2018, 10:30 AM
Also, tried a couple of usb cables I know work, so removed that from the equation.
Old 01-29-2018, 10:59 AM
interestingly, i checked the 11r editor version and says 1.0.0 - maybe thats normal. I keep installing the 1.2.12 eleven rack file (maybe irrelevant) but doesn't seem to help or change the 11r editor version.
Perhaps this means nothing.
I checked the firmware version on unit: 2.0.1, build 0.1.5.7
Again, not sure if this helps
Old 01-29-2018, 03:00 PM
Benoni's Avatar
The Eleven Rack Editor is at version 1.0.0, don't confuse that with the firmware on the Eleven Rack unit, or the driver.
The current driver is 1.2.12 (for OSX) so you are good there.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
SSD 4 and instability nozzles macOS 2 01-23-2012 07:28 AM
Instability of 7.3 midi sordino 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-13-2007 05:35 AM
General instability in PT7, looking for help. deafguy Pro Tools TDM Systems (Mac) 12 04-30-2006 11:02 AM
Bluetooth and Instability? Mount Royal Pro Tools TDM Systems (Mac) 1 09-09-2005 05:14 AM
System Instability With DR-008 Amerihudge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-27-2003 11:15 AM
