Old 01-10-2018, 07:57 PM
Grey Grey is offline
Default Re: DOES PT 10 HD work with Mavericks?
The only problem, I am having is getting a Mavericks Install.
Trying to update from HD8, to HD10.
Old 01-11-2018, 02:51 AM
crizdee's Avatar
crizdee crizdee is offline
Do you mean the Mavericks installer from apple...
https://support.apple.com/en_GB/downloads/mavericks
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-11-2018, 06:24 AM
Thanks Chris
I may be wrong??, but these are all Updates.
I did not not see a Installer for 10.9
Old 01-12-2018, 06:34 PM
WernerF WernerF is offline
I had to go to eBay and buy an installer. Pretty cheap and it’s worked great ever since. Needed the updated OS for various plugins and other stuff.
Old 01-13-2018, 02:22 AM
crizdee's Avatar
Thanks Chris
Yes sorry these are updates and you need the main installer.
I have found its possible to get El Cap / Sierra and High Sierra but anything before that is not available for download from apple.
As mentioned you can buy installers off ebay on usb sticks.
Chris
Producer, Engineer,
www.ukmastering.com
  #16
Old 01-13-2018, 09:56 AM
Raoul23 Raoul23 is offline
I’ve just gone back to Lion I tried Maverick for a week and for me it was not as stable as Lion.
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
  #17
Old 01-30-2018, 02:31 AM
Tried Maverick again this week but still no joy. The 2 plugins causing issues are soundtoys echo boy and slate VTM
If i open a session with a few Echo Boy instances in it just crashes. If i open the session with them inactive and then activate them all is ok.
VTM (1.1.13) If i click on this plugin in the session i get memory error issue and ProTools Crashes.
Anyone out there using these plugins in 10.9.5 with no issues??
Raoul Crane
  #18
Old 01-30-2018, 09:50 AM
Samanthas Dream Samanthas Dream is offline
Slate doesn’t work too well with that OS.
Echoboy should not be a problem, used it all the time.
15 years as PTHD User, Protools 2018 Ultimate, 24 Channel iCon D-Command, Avid Omni, Lynx Aurora 16, (2) BLA Modified 192 I/O’s, DigiPre, Way Too Many Outboard Compressors/EQ’s/ETC, where did all my money go????
  #19
Old 01-30-2018, 11:25 AM
TDM or native version of echo boy, and how many instances in a session :)
Raoul Crane
  #20
Old 01-30-2018, 01:11 PM
My work flow for TDM was always use TDM for tracking and them convert to Native for mixing. I used on average 4 instances of Echoboy per session, some more, some less. I’ve cant remember ever having an issue Exhoboy or any Soundtoys plugin.
Mbox 2 new driver for Mavericks just doesn't work arjohe FireWire & USB Audio Interfaces (Mac) 3 08-01-2014 04:09 PM
Mbox 2 new driver for Mavericks ust doesn't work arjohe Pro Tools 11 1 07-12-2014 02:52 AM
Artist Control STILL doesnt work with Mavericks!!! Hello? Anybody from AVID there? romanoffski Artist Series 4 06-15-2014 08:51 AM
Logic pro and logic pro x doesn't work after mavericks Sanderb Artist Series 3 12-20-2013 12:13 PM
Kontakt 5 does not work at all with Mavericks OSX 10.9. Dave S. Virtual Instruments 2 12-13-2013 12:13 AM
