New (for me) recording playback problem
I'm having a problem in 2019.6 that I don't seem to have had before. If I have a track with plugins and I record on it, then play back, the track is out of sync. If I turn off record or delete the plugins it goes back in sync. It doesn't affect recording as I use low latency mode and monitor through my Apollo.
Delay compensation is on and I'm outputing directly to the main outputs for monitoring. All plugins are disabled while in record mode. Did a setting get reset? Did this always happen? Any thoughts about this would be appreciated, Thanks |
Re: New (for me) recording playback problem
Have you setup a mastering track with mastering plugs active that is running to your monitor outputs? I usually get latency issues when recording like this... if so setup a monitoring track and sends all your subs there you can swap between the two as required....
The other thing I have tried is “save as” your session then commit all the relevant tracks this works well where you have a lot of plugs active. You can then keep the committed ver and/or import the new tracks back to the original session. I have another session where a have this sync issue where first run through I have a clip out of sync yet it is where it should be but the sync issues goes after a second or third run through.... that one is even weirder to try and figure out.
Rob MBP 15 2018 macOS Big Sur 11.6.8 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II ........and a bowl of M&M's |
strange problem with recording playback | winip | Pro Tools 10 | 1 | 07-25-2013 04:37 PM |
MIDI problem - Seems to be recording, but I can't hear anything on playback | thefire | Pro Tools M-Powered (Win) | 6 | 11-07-2012 01:06 PM |
Problem with playback and recording | ribscoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-28-2008 01:10 PM |
Monitor Playback Problem recording... | Strantz | Pro Tools TDM Systems (Mac) | 1 | 07-04-2005 06:16 PM |
Recording/ Playback problem | Vinseph | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-24-2002 08:01 AM |
