Old 09-22-2010, 05:01 PM
TLK Tom TLK Tom is offline
Lightbulb Xpand 2 - missing presets?
Hi guys, just a quickie:
did a complete reformat/reinstall of PT straight to 8.0.4 a few weeks back via the latest installers from the digi website, but it appears that all my presets are missing in xpand/hybrid. Just to clarify, the patches and sounds are all present, but when i go to the preset drop down (in the global plugin GUI) there is only 'Factory Default' and nothing else.
Is there any way to rectify this?
Cheers in advance,
Tom.
Old 09-22-2010, 10:31 PM
flommer flommer is offline
Default Re: Xpand 2 - missing presets?
Maybe your Root folder is tweaked
Preset(menu)>settings preferences>Set root settings folder...
When you click that, you should be looking at an "open file dialog" and you want to have that set to the "Plug-In Settings" folder. Don't select the named plugin folder for the plug you have open, you are just selecting the folder where all the individual plugin settings folders reside. The way you choose it is a little counter-intuitive..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 01-16-2011, 05:57 AM
spidey01 spidey01 is offline
Thanks Flommer
Old 12-01-2011, 09:42 AM
themightyrumpus themightyrumpus is offline
Talking Re: Xpand 2 - missing presets?
THANKS!!
that was totally the problem
stupid Xpand!........
Old 01-16-2017, 04:11 PM
WAXLTD WAXLTD is offline
Having this exact issue now with 12.7 -any new solutions?
Old 01-17-2017, 07:13 PM
unkJE's Avatar
unkJE unkJE is offline
With Windows, on PT 11 (and its probably the same for PT 12), the Default Location for the Xpand!2 Presets Folder is in the 32-bit Program Files -
C:\Program Files (x86)\AIR Music Technology\Xpand!2\Presets
If so – copy the Contents of the Presets Folder and place them in a Folder named: Xpand!2 which you place in:
C:\Users\User Name\Documents\Pro Tools\Plug-In Settings
In this Xpand!2 Folder - create a Folder for your User Presets – name it:
50 User
Check to see if you’ve also got a (Creative Collection) Xpand2 Folder (Xpand2 - without the exclamation mark)
If so, you can also transfer your Xpand2 User Presets to your 50 User Folder
In Pro Tools>Setup>Preferences>User Library
Set the Root:
Pro Tools Studio 2024.3 * SSL UC-1 * Digidesign Command 8 * TECH 21 SansAmp 2.0 * Xvive U3 2.4Ghz Wireless Microphone * Shure SM57 & Rode NT2-A * Fender 30 & Champ 12 valve amps * M-Audio Axiom Pro 49 * PreSonus Speakers & Monitor Station V2 * Lenovo W520 laptop Type 427637U (32 GB RAM) with extra-Ports Dock + SSDs: 2 @ Samsung T5 + 1 @ Samsung T7 * 3 Screens: 15.6” Laptop + 24” BENQ GL2450-B + Samsung 27” CT550 curved Monitor * best Wife!
Old 01-19-2017, 07:56 PM
Thanks, much appreciated. We're actually on Mac over here, should have mentioned that. We re-installed the latest version of Xpand!2 and it seemed to resolve itself.
Old 01-19-2017, 08:18 PM
unkJE's Avatar
Good to see you got it working!
Think I read for "the latest version of Xpand!2" - I should install v12.0 from my Avid account - not from Application Manager (I don't know App Mngr's Xpand!2 version number).
Just out of interest - which did you install?
Old 01-22-2017, 03:18 PM
I believe we downloaded manually from our avid account. We've definitely had mixed results from application manager, and tend to do things manually.
Old 03-23-2019, 03:45 PM
Lado Lado is offline
So here's another twist... for the sake of what I thought was efficiency, I moved my user files such as Documents, Music, Pictures, etc. to my E: drive when I installed Windows 10 because I wanted my C: drive dedicated to audio recording (using Sonar). After installing Pro Tools 2018.12 I found that Xpand!2 had no presets. Following the above comments, I've been looking for the Xpand!2 *.tfx files and have yet to find them, although I did find a bunch of *.ptxp files in an Xpand!2 folder and tried copying them to the Program Files (x86) as described above, but no luck. I'm hoping I don't have to reinstall Windows and start all over. ;-(
Xpand - Factory Presets Don't Load innermusic Virtual Instruments 15 07-12-2012 03:11 PM
1 band EQ settings missing and Xpand missing? rockguitarist1255 Pro Tools 10 5 02-19-2012 04:33 PM
how to change presets in Xpand via Midi? kalony Virtual Instruments 3 02-05-2011 11:28 AM
New Xpand user....slow going through presets Gothboy Virtual Instruments 0 04-12-2008 06:43 AM
Can't View Xpand! Presets? The Dougfather Virtual Instruments 1 07-30-2007 07:08 PM
