Anybody tried iSCSI over 10Gb ethernet?
I was wondering if anyone has experience with both 1Gb and 10Gb and ethernet with an iSCSI SAN storage system and what kind of performance one can expect.
mike |
Re: Anybody tried iSCSI over 10Gb ethernet?
I don't think ProTools supports recording to/playing from harddrives over a network, does it? At least not yet.
Brandon |
NeveSSL,
You can record to a SAN system over a network (Gb ethernet or Fiber) because the drives appear on the desktop and behave like drives connected directly to your computer. mike |
Ahh... ok. Sweet, Mike. Thanks!
Brandon |
are you using a iscsi San at the moment? I would recommend checking with the manufacturer first. Not all iscsi San systems are usable for recording with protools. There are a few that work with Protools by fooling it in to believing the raid is a single local drive (StudioSan is one) . Just because the drive appears on the desktop does not mean it will be recognized by Protools as a 'local' drive. Wish it would though :) Pete |
Hi Petevsi,
I'm no longer using the iSCSI device. It was a StudioNetworkSolutions x-4. It worked fantastic with 7.3, but then completely bombed with 7.4. That was when I gave it back. mike |
I always felt the problem with iSCSI is the packet size is same as TCP/IP networking. Where SANs use larger packets and streams. Are you modify the packet size to run iSCSI?
Steve B. ---------------------------------------------------------------- If you think you can or if you think you can't, you're right. |
ProTools Low On Memory - But System Shows 10GB Free | Trailerman | macOS | 13 | 01-13-2012 07:46 AM |
Help!! Constant 9128 and CPU power errors - 8 Core, 10GB RAM 10% CPU used | johnnybigmoose | macOS | 8 | 08-24-2011 10:18 AM |
ISCSI over NAS | DJMoley | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-25-2010 02:54 AM |
why am i always out of memory with 10GB RAM | regis | Pro Tools TDM Systems (Mac) | 1 | 12-18-2009 01:57 PM |
10gb of memory? | digifriend | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-19-2008 01:33 PM |
