Old 12-05-2018, 02:04 AM
TrentWilliams TrentWilliams is offline
Default DNxHR No Longer Compatible .. ?
Hey everyone,
Transcoding some video today with Compressor, I had a notification tell me DNxHR is now a legacy format which will no longer work with future releases of macOS .. ?
Does anyone know anything about this?
https://imgur.com/QjQnYmo
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 12-05-2018, 07:02 AM
its2loud its2loud is offline
Default Re: DNxHR No Longer Compatible .. ?
It is seemingly true as Apple continues its move to all 64-bit applications.
https://www.pro-tools-expert.com/hom...e-for-this-now
However, this doesn’t mean it won’t play back the DNXHD format as long as you have the codecs. It just means Apple’s native apps like compressor and final cut will not support the codec moving forward.
Old 12-05-2018, 10:18 AM
tom_lowe tom_lowe is offline
No. Not only will FCP X etc not support it, but future support will have to be built-in to the app directly. Most (like Pro Tools, Davinci Resolve and Videoslave) already have done this.
The original 32-bit QuickTime application where you could add CODECs is going.
Old 12-16-2018, 12:36 PM
MatzeHD MatzeHD is offline
May be they want to push the noob ProRes codec? ;O
ProRes is a bad ineffective codec!
Old 12-17-2018, 07:10 AM
Based on what!? Bizarre comment.
Old 12-18-2018, 03:00 AM
From my own experimence and comparison.
ProRes HD codecs are very bad, all profiles until Prores HQ are not recommered.
ProRes use high bitrates and a less CPU load, but the codec is very ineffective!
Example, If you use ProResHQ like for 1080P60 in 4:2:2@10bit, the bitrate is ca 440MBit/s and you have on some details compressions artefacts!^^ A good h264 encoding with the same colour resolution, looks better with a 1/3 from the Bitrate.
Sony XAVC Intra Codecs in h264 are extreme good end effective to the bitrate and it looks much better with similar or lower bitrates as Pro Res, but you have a high CPU load for encoding and decoding.
DNXHD or DNXHR are better too in the most cases and more effectiver to the bitrate like Prores and is a good Offline Codec for mastering or intermediate rendering etc..
Old 12-18-2018, 02:14 PM
Well I'd be interested to see examples, but I think you're the only person I've ever seen complain about ProRes!
Old 12-18-2018, 03:52 PM
We don't use ProRes since some years anymore for highquality rendering, intermediate rendering or videomastering or archiving. Sometimes only if we need fast a reasonably video for presentation or beta master etc.
If you need a fast encoding time for some applications, it is ok or for some semi professionell productions with lower hardware equipment.
We made some test and the quality is not good in relationship to the size from the files and for professional works.
Here is a older comparsion with a difficult content, captured from a uncompressed source via HDMI and 1080P60@440Mbit/s Pro ResHQ and 1. Generation
https://s15.directupload.net/images/181219/k8zpltd8.jpg
You can see many blocking artefacts, if you zoom some levels in, banding and compression artefacts on the sky, in the trees, in the front of the street and so on. This looks like typical MotionJPEG singleframe compression codec and this on these high bitrate and only 1. Generation, this is not optimal for a master or for further re-compression or archiving.
Here are the next older example with a difficult content:
https://s15.directupload.net/images/181219/odd4uakj.jpg
Btw,the artefacts are not from the JPEG picture compression, its only with a 2:1 compression from the original bmp snapshot for upload here!
Little anecdote:
Disney was approx for 8-10 years ProRes "Fan" and made rescans and archiving their repository in Prores! Laters they notice this was not good enough and to bad for further mastering like HDR etc and they made fully new rescans again with lossless ACES singleframe@16bit archiving.
Old 12-22-2018, 07:44 AM
rhumphries rhumphries is offline
So I've read that Avid will not be affected since they have written their own codecs for use within the app, but Protools, as I understand it, still uses Quicktime when bouncing to video. Does anyone know how this will be affected?
•HD Native, Omni, BlackMagic Intensity, i9 9900, 32GB Ram, Windows 10 pro PT 2020.5
www.TakomaMedia.com
HTML code is On
Best DNxHR Preset for working with video in Pro Tools stewart@3p Post - Surround - Video 18 03-10-2018 03:50 PM
How much longer do you think... mtung ICON & C|24 4 12-30-2016 03:44 PM
DNxHR Marcel Risberg Post - Surround - Video 8 04-21-2016 11:17 AM
Digi 003 Rack no longer compatible with Fostex VC-8 ADAT?? rojc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 08-02-2014 02:12 PM
The longer I have my 11R the better it is strangedogs Eleven Rack 6 02-10-2013 04:29 PM
