What is Cut All Automation?
2019.10 added a new shortcut called Cut All Automation.
Is that the same as Delete All Automation? Does it cut all automation from beginning to end of all regions on all shown and hidden tracks? Why would I want to cut that instead of deleting it? How could it be useful to cut ALL automation and paste it somewhere else? From the release notes: Cut All Automation Key Command |
Re: What is Cut All Automation?
should be pretty trivial. cut something to clipboard and paste it from there to somewhere else
The difference is how the breakpoints of your selection in and out point will be connected after the automation in-between has been deleted or cut. Delete and you create a "ramp" from existing breakpoints before and after your selection. Cut and you create new breakpoints at in and out of your selection.
Thanks Henning! That is very helpful.
Also, now I understand that this command does not cut all automation from the whole session - just all the automation from a selected track and portion of the timeline. Thanks! |
PC workstation: Windows 10 Pro i7 12700K RTX 2080ti 64GB DDR5 5200mhz RAM 2 Samsung 980 Pro 1TB SSDs Samsung 850 Pro 1TB SSD LG 34" Ultra-Widescreen monitor Pro Tools 12.4 A loaf of bread A stick of butter A lot of rye whiskey |
Made my day! Pleased to help :)
That's a great question and it made me learn something new. @henningaround thank you for the answer.
i7 5820K, 32GB | Windows 10 Pro, PT 2021.10 Ultimate | RME FF802 |
After the selection cut process, the automation line is still there and if you move the volume fader, it goes back on line. is there a way to clear all automation ?
You can clear all automation for a selection by clicking edit/clear/all automation
https://youtu.be/R9F8gxjLfg0
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
difference between MIDI automation and Audio automation on Instrument Track? | mariam | Getting Started | 5 | 04-28-2016 03:55 PM |
Import automation plug-in automation from an outside source? | idrejected | Post - Surround - Video | 0 | 07-06-2015 02:56 PM |
MIDI Automation to Audio Track Automation | BBKBB | Pro Tools 10 | 6 | 11-28-2012 01:56 PM |
Protools Automation to AAF Media Composer Automation | TommyT | Pro Tools TDM Systems (Mac) | 1 | 08-10-2011 01:40 AM |
Convert MIDI automation to audio automation | jnash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-21-2010 03:28 PM |
