Pro Tools LE does not recognize more than 1 CPU
Hi!
Iam running Pro Tools LE 8.0.3cs2 (MBox 2) on an MacPro 2x2,66 GHZ Dual Core Intel Xeon, 13 GB 667 MHz DDR2 RAM. Edit: Snow Leopard 10.6.3 Pro Tools does not recognize more than jus 1 Host Processor. I have tried to find some threads.. but i didnt find anything in this direction. Somebody know the problem? |
Re: Pro Tools LE does not recognize more than 1 CPU
there are no options to fix the bug and choose 2 Host Processors?
You think it's a bug?
Well anyway, one basic recommendation is that all multi core machines should be set to let PT use one core less than all cores in hardware setup. So, you will only be able to use the one core anyway.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Didnt find a troubleshooting link... |
It's not Logic plain & simple...
As Ben said, the way to run Pro Tools is to leave a processor available so in ur case, 1 is what u wanna use... PT is real time, not block based like Logic so u can't & shouldn't compare because they're both what they are... WELCOME TO PT ps. I don't kno why u aren't seeing the other processor but it could be an OS thing... But thatz to ur advantage anyway...
Thanks for the information!! Thanks for the information |
Pro tools 8 doesn't recognize 192 i/o | supafuzz | macOS | 8 | 01-14-2014 08:12 AM |
Pro Tools HD 9 Doesn't Recognize 2nd 192 io | oechols | Pro Tools 9 | 2 | 05-09-2011 06:18 AM |
Pro Tools can't recognize 192 I/O | Juraj Bernáth | Pro Tools TDM Systems (Mac) | 5 | 11-03-2010 08:46 AM |
Pro Tools Does Not Recognize M Box | beelofi | Pro Tools M-Powered (Win) | 3 | 01-15-2007 10:21 AM |
Getting Pro Tools to recognize Plug-ins | jlnelson19 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-11-2002 06:10 PM |
