Old 01-05-2016, 11:10 PM
stevedresser83 stevedresser83 is offline
Default plugin list height too high can't see all plugins
With all the UAD plugins being listed i now have so many compressors that some of the names are disappearing under the bottom taskbar where the mouse disappears too. Is there a fix for this? Shouldn't avid make the next row of plugins start at the bottom of the taskbar rather then hiding so you can't even select certain plugins? The same issue also arises for me with buses. Can't see bus 39-40 at all at the bottom of my screen. Must be doing something wrong here..
Old 01-06-2016, 07:15 AM
sw rec sw rec is offline
Default Re: plugin list height too high can't see all plugins
Can't scroll down them? What screen resolution are you using?
Old 01-06-2016, 10:11 AM
1920x1080 - highest resolution possible
nope scrolling down does nothing. The plugin list or bus list just stretches too high and disappears on the bottom underneath the taskbar
Old 01-06-2016, 11:31 AM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
One thing you could do is move some of the plugins you don't use to the unused plugins folder. That is not a real solution but a workaround.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 01-06-2016, 03:46 PM
yeah i may do that, just wondering why such a silly problem exists. That also doesn't solve me missing out on a couple busses/auxes
Old 01-06-2016, 03:48 PM
astroturf astroturf is offline
i dont know why they never bothered to code in the second plugin list to appear on teh right of the list, ecause of that plugins just get listed vertical forever no matter how much you have
Old 01-07-2016, 05:08 AM
You must have some massive sessions if you need to use Buss 39/40. Does changing the font size in Windows make any difference, or is that overridden by Pro Tools?
Old 01-07-2016, 09:56 AM
nikhilmulay nikhilmulay is offline
I get an arrow at the bottom of the plugin list which you click on to scroll down. Have you set the task bar to be hidden or always on top? That could be the issue.
Old 01-09-2016, 01:20 PM
The Weed's Avatar
The Weed The Weed is offline
My plug-in lists come up with a scroll delta or side-by-side, Windows 8.1, PT 12.4.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 01-14-2016, 06:12 PM
i get the plugins showing side by side not vertical. I've checked taskbar and thats not the issue. Even hiding taskbar doesn't solve the problem. Its out of view of the monitor all together. Don't understand why i have this issue and no one else does. Not a huge deal i guess. I've discovered that even though i don't see the plugins or the bus i can select them by using keyboard arrows. I'm not showing 5 plugins thats how far off the monitor its going.
High end orchestra plugin? Patill 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 20 11-05-2009 06:31 AM
Mastering Plugin Needed - not high end! Johnrg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 04-29-2009 01:46 PM
TL Space Plugin - Not in plugin list? joe.cavers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-31-2008 02:35 PM
Plugins missing in drop down list, but in plugins folder ?? mixingmadness 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-12-2007 10:27 AM
High pitched noise with plugins lowoctave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-05-2006 09:01 PM
